Bsracing Posted August 30, 2018 Share Posted August 30, 2018 So to clear up confusion that the other threads creates. All you gotta do to eliminate the load sensing valve is snout line to soft line for the rear axle correct? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 30, 2018 Share Posted August 30, 2018 Huh? Link to comment Share on other sites More sharing options...
Eagle Posted August 30, 2018 Share Posted August 30, 2018 2 hours ago, Bsracing said: So to clear up confusion that the other threads creates. All you gotta do to eliminate the load sensing valve is snout line to soft line for the rear axle correct? That, plus plug the bottom forward outlet on the front brake distribution block (multifunction valve body). Link to comment Share on other sites More sharing options...
Bsracing Posted August 30, 2018 Author Share Posted August 30, 2018 The downward facing forward outlet correct? Link to comment Share on other sites More sharing options...
Eagle Posted August 30, 2018 Share Posted August 30, 2018 4 hours ago, Bsracing said: The downward facing forward outlet correct? Yes. The one labeled "Emergency Bypass Circuit" Link to comment Share on other sites More sharing options...
Bsracing Posted August 30, 2018 Author Share Posted August 30, 2018 23 minutes ago, Eagle said: Yes. The one labeled "Emergency Bypass Circuit" The left is the front of the vehicle correct? Link to comment Share on other sites More sharing options...
Pete M Posted August 30, 2018 Share Posted August 30, 2018 yes Link to comment Share on other sites More sharing options...
Knucklehead97 Posted August 30, 2018 Share Posted August 30, 2018 Buy one of these. It adapts the hard line to the soft line so you don't have to reflare. Link to comment Share on other sites More sharing options...
