Load sensing valve.
2 hours ago, Bsracing said:
So to clear up confusion that the other threads creates. All you gotta do  to eliminate the load sensing valve is snout line to soft line for the rear axle correct?
That, plus plug the bottom forward outlet on the front brake distribution block (multifunction valve body).
