mrmel2you Posted August 8, 2018 Posted August 8, 2018 '90 Pioneer, 4.0, automatic, 2wd, ps/pb/ac/cruise. Color-blue. Floor pans are pristine, no rust (not even surface rust). Bought it on 08/06/2018, saved it from local salvage yard. Needs and engine and driver's side door. Build date; 07/89 Plan to rebuild and make it my daily driver, keep it all stock.
mrmel2you Posted December 10, 2018 Author Posted December 10, 2018 Sorry that I haven't updated this lately. "Ol' Blue" is starting to look a bit better since I first brought him home. Replaced the driver's door, installed a full gauge cluster, f & r shocks, put in a new stereo, swapped the new tires and wheels over from "The Beast" ('90 Sportruck, swb, 2.5, 4 speed). Sold it to get "Ol' Blue". List of a things in it; 4.0, auto, AC, tilt, cruise, comfort/power switch for the trans.. Lower end rattles like crazy, #5 rod bearing is about toast---#4 not so bad. Will be replacing the 4.0 before too long. Bought new carpet, headliner material, seat foam and cover. Will put those in after sealing and lining the entire cab, also putting Dyna-Mat in for sound dampening. Have new front bumper, bumper end caps, bumper guards and new rear bumper to put on after it gets painted (with new striping and lettering). Will keep updating this as it progresses :)
Pete M Posted December 10, 2018 Posted December 10, 2018 love the rims! but this section is more for the VIN numbers. you should start a thread in the projects section for ongoing updates.
mrmel2you Posted December 16, 2018 Author Posted December 16, 2018 Got it Pete :) You are 100% right, sorry about that.
JMO413 Posted May 25, 2019 Posted May 25, 2019 *E1 Cloth Bench Seat -SA Charcoal 152 Zone 52-Kansas City 1AA U.S. Dealer Retail 5KM AMES Department Stores ALM APA Monotone Paint ARL BAY 105 Amp Alternator BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHT Shift-on-the-Fly,P/Time T/Case DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle EAA All Engines EAF ALL FUEL INJECTED ENGINES-GAS ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HAA Air Conditioning JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3B STRIPE/BADGE/MOLDING/COLOR KKE LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps MB1 Black Front Bumper MBJ Black Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHM Speed Control PB3 QB3 RAA All Radio Equipped Vehicles RAB AM/FM Radio RCD 4 Speakers SBA Power Steering SCE Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z1A GVW/Payload Rating Z59 Left Front Spring Group Ix Z78 Right Front Spring Group VIII Body Model TL62 Build Date 7/16/89
jdog Posted February 6, 2021 Posted February 6, 2021 Selling Dealer: JOHN HOFFER CHRY-JEEP INC Topeka, KS
