Wounded_Fighter Posted July 29, 2018 Share Posted July 29, 2018 To top coat...? Or not to top coat...? Recently gave up on floorboards. The rust ate through my etching primer so I por15'd the whole thing. Read on the can it should be top coated to protect the life of por15 from UV etc..etc... Anyone have comments or problems with por15 in direct sun? Link to comment Share on other sites More sharing options...
PCO6 Posted July 29, 2018 Share Posted July 29, 2018 There's lots of more technical information on line than I can offer but from practical experience I would put a top coat on most things. If you're covering your floor boards with carpet I wouldn't worry about it. I've painted things under a car and they've held up just fine. Others that see sunlight have faded to flat black. I've never seen rust reappear though. A can of POR15 goes a long way. I usually pour it into small glass jars (various sizes) seal the lid with cellophane and put them in my garage fridge … next to the beer. Don't leave it in the original can. The air above the paint in the can is enough to cause it to harden and become useless. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted July 29, 2018 Author Share Posted July 29, 2018 Good to know. Mason jar it is... Link to comment Share on other sites More sharing options...
Fryedaddy Posted May 3, 2019 Share Posted May 3, 2019 UV doesn't damage POR15 other that fading it gray. That stuff it tough!! Link to comment Share on other sites More sharing options...
Limeyjeeper Posted May 3, 2019 Share Posted May 3, 2019 POR-15® PRODUCT DESCRIPTION POR-15 Inc. brings the powerful technology of polymeric isocyanate derivatives to the consumer rust prevention market for the first time, a technology vastly superior to competing products currently on the market. POR-15® is easier and less expensive to apply than epoxies, since it doesn't require mixing: and POR-15® dries to a high-gloss or semi-gloss finish just like paint, except that it cannot be scratched or peeled off. Since POR-15® chemically bonds to metal, the underlying surface does not have to be sanded before application. As long as loose or flaking rust are removed from the surface, an application of POR-15® will not only cover up the rust and prevent it from spreading, but will also strengthen the underlying metal and seal holes by forming its own membranes. POR-15 is a rust-preventive paint designed for application directly on rusted or seasoned metal surfaces. It dries to a rock-hard, non-porous finish that won't chip, crack, or peel, and it prevents rust from re-occurring by protecting metal from further exposure to moisture. POR-15 is sensitive to UV light (sun) and must be topcoated before prolonged exposure to sunlight. POR-15 is cured and strengthened by exposure to moisture and will dry faster under extreme humidity, but moderate to dry atmospheric conditions are most desirable when applying this product,because extreme humidity may cause an immediate surface cure, trapping carbon dioxide gas below the surface. When this happens, bubbling may occur. Extreme humidity at the time of application may also interfere with proper adhesion of the POR-15 coating to metal because it's almost impossible to keep metal dry under such conditions. POR-15® is a paint-like substance which acts as a total rust inhibitor and also very effective as a metal filler. Its consistency is approximately that of paint and it has very good spreadability (one quart covers 96 square feet). POR-15® chemically bonds to rusted steel to form a rock-hard, nonporous coating that won't crack, chip, or peel. It works by isolating metal from moisture; without moisture present, steel can't rust. Thin, covering coats are best. Apply second coat when first coat is dry to touch with slight "finger-drag" remaining. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 3, 2019 Share Posted May 3, 2019 POR? Witch's brew. Clean it up and do it right! Link to comment Share on other sites More sharing options...
Limeyjeeper Posted May 4, 2019 Share Posted May 4, 2019 POR15 won't stop rust but it helps stopping it from starting... Nothing really stops rust IMHO except cutting out the rot and replacing it with new metal. Link to comment Share on other sites More sharing options...
cody4359 Posted May 5, 2019 Share Posted May 5, 2019 I vote fix the pans too, then coat. I did mine in 2012 I think, and for whatever reason I chose rust bullet. I think because they claim a 10 year anti corrosion. I don't drive it much but if in were to.clean it up it would still shine. Rewired the jeep last July and pans look almost just like I left them Link to comment Share on other sites More sharing options...
