a bum with money Posted July 19, 2018 Share Posted July 19, 2018 I'm chasing down a short on my 92xj and have gotten it down to the dome circuit group. the amp draw is a bout 1.25 amps. I know that the interior lights, power door locks, power mirrors?, keyless entry and not sure what else (I poured over every wiring diagram I could find). I want to test everything in the circuit but am not sure what the circuit feeds power to. the fuse is only 10 amps so it shouldn't be to heavy. there is a keyless module in the rig but there is no fob for it, how do you test a keyless system? also I have no power mirrors. the overhead lights all work but haven't checked all interior lights yet (glove, and etc). I just need to know what all was on the dome circuit, plus any advice too I can get too. Bryce Link to comment Share on other sites More sharing options...
Jeep Driver Posted July 20, 2018 Share Posted July 20, 2018 The only other thing would be radio memory wire, constant +. Check your door switches. Link to comment Share on other sites More sharing options...
zomeizter Posted July 20, 2018 Share Posted July 20, 2018 A short would cause a fuse to fail, is this happening? If you are trying to resolve a draw that is draining your battery, suspect a glove box light bulb... Link to comment Share on other sites More sharing options...
a bum with money Posted July 20, 2018 Author Share Posted July 20, 2018 57 minutes ago, Jeep Driver said: The only other thing would be radio memory wire, constant +. Check your door switches. That makes sense, plus its not as bad as a short would be. A 194 bulb would be about 1.25 amps I think. Being a dome circuit its not so bad, just have to trace it down. Thanks 42 minutes ago, zomeizter said: A short would cause a fuse to fail, is this happening? If you are trying to resolve a draw that is draining your battery, suspect a glove box light bulb... Link to comment Share on other sites More sharing options...
a bum with money Posted July 20, 2018 Author Share Posted July 20, 2018 15 hours ago, zomeizter said: A short would cause a fuse to fail, is this happening? If you are trying to resolve a draw that is draining your battery, suspect a glove box light bulb... found the draw! it turned to be the glove box light. a simple adjustment and now it turns off. the greatest part of this problem is I now know how to locate a parasitic draw. thanks CC members. Bryce Link to comment Share on other sites More sharing options...
zomeizter Posted July 21, 2018 Share Posted July 21, 2018 nicely done... Link to comment Share on other sites More sharing options...
Minuit Posted November 7, 2018 Share Posted November 7, 2018 Kind of a bump, but this almost got me today. I noticed that the battery would go dead after a few days and found a 250ma parasitic draw on the DOME fuse. I tested all of the easy stuff on that circuit but forgot about the glove box light. I was about ready to take the dash apart to test the other components (radio, clock, etc) but I read this thread first. Sure enough, the glove box bulb was piping hot even though I haven't opened the glove box in several days. Good job and thanks for posting your fix, because it saved me hours of frustration! Link to comment Share on other sites More sharing options...
