Help Identifying This Item
Started a new "build thread" but was recommended that I post questions over here in the Tech forum which makes sense...I will probably have several while reviving the Comancher but will keep them separated  in different posts in hopes of helping someone else.
Found this round object floating around the engine bay, appears to have a vacuum line and sensor hooked to it. Not quite sure what it is and where it mounts??
5 minutes ago, Griff04 said:
That’s awesome, just what I needed. The bumper is pretty banged up which pretty much explains it just laying around.
Thx,
Griff
You can relocate it, many of us have.
I made a new one and moved it.
That pic shows the holes on the "face" of the bumper, but I'm not sure I've ever seen one mounted that way. The holes to mount it on every bumper I've seen are in the same location (on the right of the bumper) but on the bottom. If you decide to put it back in the stock location you'll see.
