HVAC Vacuum Line Routing
When I first got my truck there was a broken vacuum line routed through the firewall to the heating and air conditioning unit in the dash.  Here's a pic, outlined in yellow.  It was broken off where you see the boot I added near the firewall.
As you can see, I routed it to a t fitting that routes to the football canister behind the front bumper.  Here are some close up shots, in case the image above isn't clear.
I did a lot of research and a lot of pics before doing this, but there wasn't any clear info on where this line actually should have gone.  So I picked what I thought was the best option.  The question is, where does it really go?  Anybody have any good shots?  91 HO electronics.  Thanks.
Here's a bigger shot from just before I fixed it.  Shows more of the heater hoses.
Yes, the hot water control valve is plumbed into the heater hoses.  Would definitely like to know what that's for, though.  Doesn't show up on my YJ.  As far as cruise control, the steering column had a cruise control selector, but the wire was cut at the stalk when I got the truck.  I have not fully verified all cruise control components are gone, but it is the intention to remove that option entirely if there are any remnants of it.  I just haven't gotten there yet.
Would like to help ID it for you, but my vacuum lines are nothing like OEM anymore since I did the new 01 intake manifold. I don't see your vacuum check valve in there either..    :thinking:
Thank you for taking the time to look.  If I recall, that line may have dumped to a check valve previously.  It looked like the PO tried to fix it incorrectly once or twice and I was guessing because reference pics are non-existent, and the FSM and diagrams I've reviewed are no help with this one.
Maybe somebody else with an HO can chime in, perhaps provide a decent pic of how it looks.  Basically there are two lines coming out of the HVAC, one white and one black.  Anybody know where the black one goes on an HO model?
Circling back around on this.  If anybody has a 91 or 92 MJ, or even an HO XJ, and can take a pic of exactly what the black vacuum line running out of the HVAC system runs to, I'd appreciate it.  Please reference the pics in my original post to see what I'm looking for.  There are two lines, a white one and a black one.  My black one broke and I have no idea if I have it routed to the right spot right now.  Vehicle was optioned with cruise control, but it was removed prior to my ownership.
Thanks in advance to anyone that takes the time to help.
On my ‘91 there is a tee in the main vacuum line from the reservoir at the firewall near the point the AC lines go through the firewall (also where the vacuum line passes through the firewall).  There is a check valve in the connection.  I’ve relocated my washer bottle (from a XJ) there to make room for the double diaphragm brake booster so the view in my photo is partially blocked.
You can see that tee in your photo but it looks like there is nothing connected to it.  Where does the vacuum line that is dangling there go?  It look like it may have half of a check valve on the end.
Your line is connected at the tee for the cruise control vacuum line.
 Thank you very much.  This should help me figure it out.
Thanks for all the help. Between Keyav8er's pic, a real hard look at the FSM, net searches leading me to other forums, and taking a look at this nice looking 91 MJ I saw at a local show this past weekend, I came up with this.  Transfer case and HVAC routed to the same check valve:
If this is incorrect for my 91 HO, somebody please let me know.  I think I got it though.
40 minutes ago, HOrnbrod said:
As I recall, that was the way my 91 was before I moved the vac canister into the cab.   :L:
I was staring at pics and the FSM for about an hour when I finally realized every pic I had been provided was for a 2WD model.  The FSM referenced HVAC and 4WD vacuum sepearately, but never showed how they connect together vacuum-wise.  So through deduction, this is what it looks like the FSM would direct you to do.  Thanks for the validation.
The vacuum-controlled hot water valve was removed on the later XJs. Most people pull the water control valve, replace the heater hoses with 97+ hoses, then remove the water valve vacuum line. Makes for a much neater install and the all HVAC functions work as before. It does allow continuous water continuously circulation through the heater core, but and heat is blocked out of the cab by the HVAC doors. Unless there's a reason you want to keep the troublesome water control valve.  :dunno:
Added to my list.  I was hoping something like this would work, as it seems overly complicated as it is.  Thank you.
Make sure you cap the vac line coming out of the firewall if you delete the valve (I used an actual CAP as opposed to a sheet metal screw or a golf tee).  Any open vac line on the pass. side will cause the HVAC door switching to default to defrost vents.
  • 1 month later...
23 hours ago, Michael Buskirk said:
What do you do with the coolant reservoir and associated lines?
Yours is a 90 and there is a different procedure for that. do you have a radiator with a cap on it or only the pressure bottle with a cap?
