I am not sure where a thread like this would go. I just wanted to compile a basic understanding of what tires to run on what axles (d30, d44, d50/60, 8.8, 8.25 etc)
I know people draw the line at 35s on a d30, 37s on a d44 and 37+ for 1 tons. But what are the actual limits of these axles to the best of our abilities. I know driving style, intended use and terrain affect numbers. As do sleeves, truss kits, chromo axles, carriers and the like.
But from experience wise say, on a d30/8.25 combo how big can you go? Some people say its just as strong as a d44 because u-joints are the same size. I know of a fellow with an xj (d30/8.25 combo) on 40" tsl's here in Florida. I know @12valve.tj knows him and his youtube channel has videos of his setup. Mind you most of the time its on the street or on swampy/muddy trails, but he is still making it work so whats the limit?
Buddy of mine has 38s ground hawgs on his xj
4.0 nv3550
dana 30 open carrier 4.10s
29 spline 8.25 powertrax no slip locker and 4.10s
and he hasn’t broken a shaft yet... but he does carry spares just in case....
well he doesn’t rock crawl but he does mud a lot and beats on it when he wants to and it’s his daily
there are a LOT of variables in play here.  terrain, driving style, tread pattern, locked/open, truss, etc.  A dana 30 is way tougher than its name implies, but it has limits.  personally I wouldn't go bigger than some 33" mud terrains, but I'm a cautious person since I usually need to drive the truck home.   I put a 44 in the front of my truck because I wanted more of a project than just a bolt-in 4wd conversion.
and for every guy that runs giant tires on a dana 30 and doesn't have any problems, there's a guy like me.. who cracked a ford 9" case in half (we think by dropping it on a rock), so nothing is invincible.  :doh:
I was going to mention that cherokee too Walt.
And Pete there are plenty of variables, and I'm sure there is a guy out there that if you give him anything he will brake it. But beyond the scope of just a d30 all axles of sorts. I guess it depends on what driving you are going to do as a pavement princess has different requirements than a rock crawler/mud/ trail rip or even a DD
I am not sure what my end goal is either 35s, 37s or 40s. Probably going to stay at 35s as it'll be a comfortable/reliable spot on a well built d30. Work with what you got right?
Decisions Decisions :dunno:
But just as a reference
Front axle:
HP D30-
LP D30-
HP D44-
LP D44-
D50/60-
Unimog axles-
2.5T Rockwells-
Rear axle:
Ford 8.8-
Chy 8.25-
Chy 8.75-
Sterling 10.5-
D70-
Ford 9-
D44-
14bolt-
D35-
Amc20-
Chevy 12 bolt-
Aftermarket crate axles?
ProRock 44-
Prorock 60-
G2 44-
Currier?
don't for get to consider how much driving it'll see and the local rules about lifts and tire coverage.
@saveevryjp1998 i was thinking the same thing about a 44, but id rather build something I already have to handle what I need it to. The only down side to a d30 is that you can only go down to 5.13 gears and not 5.38 like a d44. With that 2.5l and 5.13s, 35s are as big as I would want to go to still be able to drive on the highway. But if I rebuild the motor for more power I maybe able to go to 37s
7 hours ago, saveevryjp1998 said:
I thought about that with my 86 2.5 if I were to lift it. My thoughts are I'm wasting my time with an offroad 2.5. I like it for the street and think there is plenty there and efficient as it was designed for, but as a lifted offroad truck with 37's is not realistic. Mine 2.5 will not ever have anything other than fresh stock setup to make a superb clean cool little 30 plus year old truck with great economy.
I totally understand this but as someone who wanted a solid axle 4x4 truck has always been a goal of mine. Even to the point I thought about doing a solid axle swap on my 2wd ranger. But I'm glad I was able to scoop up my mj, and build it/wheel it. 35s will be my reasonable limit
 Yes building it as a jack-of-all-trades is my goal. Not really good in one area, but can handle a little of everything tyoe of trail rig
