swappin engines
It's a well covered topic if you search.
But yes, the tranny needs to be changed.  You may want a new rear axle since likely the one you have sucks, but it's not a requirement.  Tcase may need a different input if you 4wd.
You will need to do modifications to the firewall and radiator support, and probably many little things I am forgetting.
As others have echoed, theres a lot of information available by searching on the forum.  With that said, its a BIG endeavor, especially with the 86.  The 86 will require a lot of firewall beating/modification.
Additionally, you will have to do a lot of cutting on the front of the engine bay to fit the 4.0 radiator/radiator support.
