bigmistake Posted April 21, 2018 Posted April 21, 2018 I've been looking for a MJ for a long time, and it seems like I keep seeing 2wd, 2.5L trucks. Is it a straight swap to plug in a 4.0L engine? Based on what I've been seeing, I'd likely swap the engine and do the 4WD conversion from a donor XJ. Thanks!
Pete M Posted April 21, 2018 Posted April 21, 2018 it's exactly as hard as stripping a truck down to the bare bones steel, then doing the same to an XJ,) and then reassembling it all into 1 awesome rig. for what it's worth, the 2.5 is a fine little engine. it just need the proper gearing to match the tires you want to run. a 4wd swap is much easier than a full on engine change.
omega_rugal Posted April 21, 2018 Posted April 21, 2018 if you can get a 2.5 with little rust it`s the best for a project, the later the model, the easier to swap things over, also there`s a plus that the rear axle will be 4.11 or at least 3.55...
carnuck Posted April 22, 2018 Posted April 22, 2018 I was going to suggest swapping the spare 4.0L I have for a good 2.5 but I’ll probably be selling mine when I get back to where it’s stored.
