Recently upgraded to a odyssey battery. Is it beneficial to upgrade to a high output alternator? Will this maximize the performance of the AGM battery? Running just a few accessories like a couple offroad lights and a winch. Thanks
19 minutes ago, DirtyComanche said:
The only time it will matter is if you're winching for a long time.  A worthwhile upgrade, but certainly not a requirement.
Great thanks
12 hours ago, MeanLemons said:
If you upgrade the alternator, don’t forget to upgrade the cables to match as well
Mine isn’t charging so I need one. Is there a better alternator out there, off a dodge maybe, that would be a wise choice?
Just looked on DIY forum, didn't see one. Know there is a 130+ amp Dodge upgrade. Check Cherokee forum. Cruiser or Don may have a link.
Then Please do a DIY write up for us here.
