I have found some smokers windows (notsure ifthats what the moveable triangle windows in the doors are called).
They are a cherokee in a pickapart yard. The doors are electric windows and the panels are crap.
My questions is: Is it easier to remove the window and restall it in my doors? Or install the manuel window regulators in the other doors?
Easier to switch just the smokers windows . Be sure to bring a drill battery so you can lower the power windows to get the vent window out . When you lower the window you'll have to pull the nut (or torx bolt ) to allow the window to go all the way to the bottom of the door to allow enough room to pull the vent window .
be aware that the vent windows are prone to whistling and leaks.  sometimes a penny shoved into the latch can help.  :thumbsup:
have vent windows in my 89 and had them in the 90 ---- X2 on the pennies or glue a shim on
I got the windows out and they are in great shape!! Thanks Stroker for the idea to use a electric drill battery! It worked great. I had people stop and ask me how I did got the window to go down to easily lol
Glad to hear it worked out good for you
