Blue88Comanche Posted November 25, 2017 Share Posted November 25, 2017 So got up this morning at 4am, its 36 degrees outside and i had to bypass my heater core the yesterday cause it was leaking bad. Left the house bundled up and cruising on the interstate to meet up with a jeep and there was some clanking noises (not many) then the transmission stopped receiving power from the engine (engine act like tranny was not in gear). The clutch also felt like it lost pressure. Coasted to a stop on the side of the interstate and called AAA. 2 hours later I'm home with the jeep. I let it sit for a while and now the clutch has pressure but when i put it into gears 1,2,3,5 and Reverse, Nothing happens. Only 4th gear seems to work. At first i thought maybe the clutch blew out, but now I'm wondering if the tranny died. Thoughts? This is in reference to my Blue Comanche, see sig for details. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
87MJTIM Posted November 25, 2017 Share Posted November 25, 2017 What transmission? if its a BA10, it may not be worth fixing. Shift forks broken? does it make noise when shifting? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted November 25, 2017 Author Share Posted November 25, 2017 What transmission? if its a BA10, it may not be worth fixing. Shift forks broken? does it make noise when shifting? Ax-15It feels like normal when shifting, i can feel it go into gear like normal... But only 4th gear works.Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
omega_rugal Posted November 25, 2017 Share Posted November 25, 2017 counter shaft inside the tranny has left the building Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 25, 2017 Share Posted November 25, 2017 Transmission's shot. 4th gear is the 1:1 ratio, straight through engagement. There's something wrong the shift fork and/or sleeve to engage the other gears. Link to comment Share on other sites More sharing options...
DirtyComanche Posted November 26, 2017 Share Posted November 26, 2017 1 hour ago, omega_rugal said: counter shaft inside the tranny has left the building 1 hour ago, HOrnbrod said: Transmission's shot. 4th gear is the 1:1 ratio, straight through engagement. There's something wrong the shift fork and/or sleeve to engage the other gears. These. She's broken. Junkyard replace, rebuild yourself, buy a reman, or buy a new one. Link to comment Share on other sites More sharing options...
Blue88Comanche Posted November 26, 2017 Author Share Posted November 26, 2017 Yay.... I killed an ax-15... well it was a Junkyard find... thanks for the help everyone! I will be looking for a reman unit I suppose. Possibly converting to the AW-4. I’m not sure yet.Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
