So the wiring in my jeep is getting pretty bad, along with the tired renix 4.0 I'm looking to do the dash and high output swap, I found a running and driving 98 Cherokee for $200 I want to take the engine, dash and wiring and swap it into my jeep, the donor has an aw4 but I would like to keep my ax15 I previously swapped into it. Is that a possible option to use a wiring harness that is set up for the aw4 and keep my ax15? Also can I use my existing pedal assembly or will I have to find one from a 97+? Anything else I need to know before I do the swap? Any helpful tips would be greatly appreciated, thanks.
Like Pete said.  Check out the build threads and diy project sections for 97+ swaps.  Everything you're asking is doable, it's just a matter of finding the info in the threads.
