Rear Lift Springs
23 hours ago, Pete M said:
what's your price range?  AALs (either aftermarket or junkyard) are the cheapest, full new leafsets are the most expensive.
I'm looking at options.  I seen one vendor selling  leaf springs for $600.  Is that the going rate or are there other alternatives.
I'm looking around for rear springs in the 3-4.5" range.  If any of this is wrong, somebody correct me...
I believe General Spring has the cheapest decent spring available, but the biggest you can get are metric ton springs, which are a smaller lift than what we're looking for.  Hells Creek (CC vendor) springs can be had for about $600 plus shipping.  I got a quote from Alcan, and they're at $750 for a custom set, and I think that was shipped.  From what I've read, those are the only real considerations for somebody who wants their suspension to work properly.  Those just going for height are generally advised to go AAL and shackles, and those will sag and ride rough.  Rusty's has MJ lift springs, as does Rough Country, but I've not read anything on those springs that would lead me to believe they're the quality I'm looking for.  That might be all that's available.
What I'm finding is that if you want anything bigger than metric ton springs, you're in the $500+ neighborhood for the pair because they're basically being custom made for you.  I believe this is why you see a lot of guys go SOA at ~5.5" and spend that money on the front.  I'm leaning towards Alcan right now, as they are custom made, and tuned to your bed length, driving style, etc.  But Hells Creek seems to have the edge on the MJ research and development.  Tough choices.
you can try using junkyard leafs to gain lift.  don't quote me, but I think it's 4wd S-10 and Dakota that can be made to work.  but there's no guaranty of how much lift you're going to get or exactly which leafs you use to get there or even how many times you need to take the rear suspension apart and put it back together before you're happy with the results.  just be sure to retain your main leaf so the tire is in the proper location in the wheel well (assuming your main is less rusty than mine was).
Unless you know something I don't know., Hells Creek has been out of the leaf spring business for some time now.
I called them in May and talked to the owner.  They still sell the springs but don't manufacture them any more.  The new manufacturer uses the Hells Creek patented design.  He said everybody thinks they're no longer selling springs, it's just that they're not making them on location any more.
