I used bolts. 1/4 inch if I remember correctly. Didn't drill anything.
Spent time at the junkyard removing hinge pins from some rear Cherokee doors (figured less wear on the rear). I got four sets since the pins on a 1986 and 1990 looked to different diameters (they were). They didn't fix the sag in my drivers door, but the bolts snugged the door up pretty good along with a really thin washer (had to file one thinner).
When I did mine a while back, I pounded out the roll pin and then drilled the hinge hole put to 5/16"... I think. Just dropped a grade 8 bolt in there. Hasn't been a problem.
