knever3 Posted August 3, 2017 Share Posted August 3, 2017 The body shop painted my rubber rain guard that is mounted on the 45 degree A pillar when you open the door. Does anyone have a source for these, I have done an exhaustive Google search and can't figure out what it is called or where to get one. Link to comment Share on other sites More sharing options...
cruiser54 Posted August 3, 2017 Share Posted August 3, 2017 You may have a problem locating our old style ones. See if you can find the more rigid and better sealing ones from 94 to 96? Link to comment Share on other sites More sharing options...
knever3 Posted August 3, 2017 Author Share Posted August 3, 2017 Just to clarify I am not looking for the entire door seal I've replaced them with the newer style ones already. The one I am looking for is the one that is mounted to the A pillar alone that is only 2' long perhaps? It is just there for the rain to get directed down to the hinge area instead of resting on the actual door seal. It is mounted on the outside body pillar not in the groove that the entire door seal is mounted. It is seen in the most left side of this picture. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 3, 2017 Share Posted August 3, 2017 I think this is what you are looking for: http://teamcherokee.com/secondary-rain-molding-seal-oem-jeep-cherokee-wagoneer-comanche-1984-1996/ Link to comment Share on other sites More sharing options...
Alexia Posted August 3, 2017 Share Posted August 3, 2017 I think this is what you are looking for: http://teamcherokee.com/secondary-rain-molding-seal-oem-jeep-cherokee-wagoneer-comanche-1984-1996/ I bought those. They are not even remotely correct. Also, they were only $16 each at the time. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 3, 2017 Share Posted August 3, 2017 The p/n is for it is 55134514 in the manual. Secondary Rain Molding Seal OEM Jeep Cherokee, Wagoneer & Comanche 1984-1996 I believe you Alex. Is it mislabeled by Team Cherokee? Won't be the first time....... EDIT: Just went and looked at mine - it looks identical. Do you have 97+ doors Alex? They are completely different. Link to comment Share on other sites More sharing options...
knever3 Posted August 3, 2017 Author Share Posted August 3, 2017 I do not, I have the '87 doors, will this still work? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 3, 2017 Share Posted August 3, 2017 IF their p/n is correct, and Team Cherokee sends the correct p/n, it's correct. Same ones I have on my 91. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted August 3, 2017 Share Posted August 3, 2017 I've never heard of anyone ordering this before. Well, except me when I had ruled out every other "water on floor" issue. I had the very same issue on both doors of both Jeeps. The MJ I was able to remove the slightly warped strips and straighten them out, and use some silicon to seal them up...with the XJ I bought new because they were trashed. Link to comment Share on other sites More sharing options...
Alexia Posted August 3, 2017 Share Posted August 3, 2017 I will take a picture of them when I get home tonight. Link to comment Share on other sites More sharing options...
Alexia Posted August 6, 2017 Share Posted August 6, 2017 The holes at the top and bottom match up, but the center hole does not match up. The material feels sturdy enough to drill extra holes to match the early XJ/MJ hole pattern. Which will be necessary since it does not naturally sit flush along the curve so it would try to pull the adhesive off over time. So they will work, but require some minor modification to work really well. Link to comment Share on other sites More sharing options...
knever3 Posted August 27, 2017 Author Share Posted August 27, 2017 Here are the pictures of my door seals. I am thinking of pulling them off to use paint stripper and remove the paint. I need to find the plastic rivets that fasten it back on before I remove them. Any chance anyone knows where to get them? Link to comment Share on other sites More sharing options...
