teamsmith Posted June 30, 2017 Share Posted June 30, 2017 This has happened 3 time so far. I go to start up truck, hold the clutch in, don't touch the gas, and turn the key. Truck starts right up but stays at high idle (2500rpm) and doesn't come down. I turn the truck off, let it sit, start it again. Same thing. On 3rd restart it settles down and behaves. I looked at the throttle linkage which looks fine (and shouldn't be in place anyway since I'm not touching the gas pedal). Would it be something int the throttle body? One of the sensors? Thanks for any help. So far it's not a huge deal since it settles down after a minute. Link to comment Share on other sites More sharing options...
AeroNautical Posted June 30, 2017 Share Posted June 30, 2017 I've had this issue for years, I narrowed it down to the IAC getting stuck open, thats the only way enough air can be sucked in to get a 2500 rpm, if the butterfly isnt open. Its not a leak, because it's intermittent. I went through 6 iac sensors, some new, some jy finds. All fixed the problem for a short while. My only guess is a bad ground or voltage for that sensor. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 1, 2017 Share Posted July 1, 2017 idle stepper motor gets stuck Link to comment Share on other sites More sharing options...
teamsmith Posted July 3, 2017 Author Share Posted July 3, 2017 Thanks for the replies. I guess my next step will be to go through all of the grounds and re-check them. It's only happened about 5 times out 30 or so starts. I haven't been driving it often that those 30 starts are maybe stretched out of 6 months. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 3, 2017 Share Posted July 3, 2017 Thanks for the replies. I guess my next step will be to go through all of the grounds and re-check them. It's only happened about 5 times out 30 or so starts. I haven't been driving it often that those 30 starts are maybe stretched out of 6 months. Your TPS is likely bad and/or has a poor ground. Do Tip 5 at www.cruiser54.com and report back. Link to comment Share on other sites More sharing options...
AeroNautical Posted July 5, 2017 Share Posted July 5, 2017 Thanks for the replies. I guess my next step will be to go through all of the grounds and re-check them. It's only happened about 5 times out 30 or so starts. I haven't been driving it often that those 30 starts are maybe stretched out of 6 months. Your TPS is likely bad and/or has a poor ground. Do Tip 5 at www.cruiser54.com and report back. Are you saying the IAC is not related at all? If the TPS is giving more fuel to the engine than it should be, I understand the idle might be a little higher, but there is hardly any air getting into the engine, I'm surprised the idle skyrockets like it does. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 5, 2017 Share Posted July 5, 2017 Thanks for the replies. I guess my next step will be to go through all of the grounds and re-check them. It's only happened about 5 times out 30 or so starts. I haven't been driving it often that those 30 starts are maybe stretched out of 6 months. Your TPS is likely bad and/or has a poor ground. Do Tip 5 at www.cruiser54.com and report back. Are you saying the IAC is not related at all? If the TPS is giving more fuel to the engine than it should be, I understand the idle might be a little higher, but there is hardly any air getting into the engine, I'm surprised the idle skyrockets like it does. TPS tells ECU throttle is open. IAC pulls back. This is a very common issue. That's why you do Tip 5 to check the TPS and other sensor grounds. Link to comment Share on other sites More sharing options...
omega_rugal Posted July 5, 2017 Share Posted July 5, 2017 TPS tells ECU throttle is open. IAC pulls back. This is a very common issue. That's why you do Tip 5 to check the TPS and other sensor grounds. how does the ECU know how much air is getting in? only throu the TPS? how about the MAP? how come cycling the ECU on and off several times eventually fixed the problem? Link to comment Share on other sites More sharing options...
cruiser54 Posted July 6, 2017 Share Posted July 6, 2017 Yes. MAP measures load via vacuum. I'm not sure. Seems to be the M.O. of a failing TPS. Unplug the tPS and see if the idle ever flares. Link to comment Share on other sites More sharing options...
Rockfrog Posted July 6, 2017 Share Posted July 6, 2017 This was what happened when my stock TPS failed. Exactly like this. Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
cruiser54 Posted July 6, 2017 Share Posted July 6, 2017 This was what happened when my stock TPS failed. Exactly like this. Sent from my SM-G930W8 using Tapatalk Yup. Always check the sensor ground circuit per Tip 5 first, but odds are the tPS is taking a dump. Link to comment Share on other sites More sharing options...
Ωhm Posted July 6, 2017 Share Posted July 6, 2017 TPS/TPS wiring is usually the cure for high idle on start up. Listen to cruiser. But while you're at it check cruiser tip 14. Throttle plate angle adjustment is a calibrated air leak and once properly set allows for TPS (closed throttle) and IAC (pintle position) to find the happy zone. That is, the best position for TPS to be adjusted and centers the IAC motor for optimum performance. Also make sure linkage always returns to the idle stop screw and no slop with the throttle plate. TPS tells ECU throttle is open. IAC pulls back. This is a very common issue. That's why you do Tip 5 to check the TPS and other sensor grounds. how does the ECU know how much air is getting in? only throu the TPS? how about the MAP? how come cycling the ECU on and off several times eventually fixed the problem? ECU also uses engine speed (RPMs) with TPS and MAP to determine the amount of air during open loop. Link to comment Share on other sites More sharing options...
teamsmith Posted July 10, 2017 Author Share Posted July 10, 2017 Thanks for the replies. I guess my next step will be to go through all of the grounds and re-check them. It's only happened about 5 times out 30 or so starts. I haven't been driving it often that those 30 starts are maybe stretched out of 6 months. Your TPS is likely bad and/or has a poor ground. Do Tip 5 at www.cruiser54.com and report back. So this is what I get for relying on my memory for the protocol of the tests. I put my multimeter on A & B of the TPS connector and got 0.3 ohms. I just re-read your tip and it said to touch the negative battery terminal. I'll go back and re do it. I've driven the truck about 10 more time since I posted this (amazing what a working A/C will do for driveability) and the problem hasn't cropped back up. I will still perform the check and report back. Link to comment Share on other sites More sharing options...
