sdougwilliams Posted June 23, 2017 Posted June 23, 2017 I did a V6 to I6 swap on my 86 jeep Comanche a few years ago. I pulled all the needed parts from a local salvage yard to include wiring harnesses and hte like. This was a Big job! as the Radiator supports needed changed, the motor mounts, and all the wiring under the hood. I decided to go with the AW4 4 speed automatic transmission which required the transmission control box which is installed under the glove box. When I was installing in the engine I learned that the firewall needed pushed back about an inch. Nothing a sledge hammer could not accomplish. The strangest thing I learned was the need to wire the torque converter disconnection circuit which operated off a separate vacuum switch associated with the cruise control. It was not hard to fix, I just wish I would have done this 30,000 miles ago. I also added the comfort power switch in the dash that required some minor wiring and the addition of a new fuse in the fuse box that provides power when the key is on. This switch adjusts the shift points of the transmission. The truck drives like a different vehicle with the disengagement of the locked torque converter when I step on the brake pedal. Additionally it shifts through the lower gears more smoothly when the converter is not already locked up. I think it locks up now about 35 to 40 mph. I hope these comments will help you not repeat my failure to completed the AW4 torque converter disconnect wiring correctly. Happy Trails
Jeep Driver Posted June 23, 2017 Posted June 23, 2017 There's no way I'd repower with a 4.0, not now. Let the purists pounce. There is just that thread ongoing here, I remained silent.
Tex06 Posted June 23, 2017 Posted June 23, 2017 There's no way I'd repower with a 4.0, not now. Let the purists pounce. There is just that thread ongoing here, I remained silent. Not even with a supercharged 4.0? :D Sent from my SM-G930T using Tapatalk
Jeep Driver Posted June 24, 2017 Posted June 24, 2017 There's no way I'd repower with a 4.0, not now. Let the purists pounce. There is just that thread ongoing here, I remained silent. Not even with a supercharged 4.0? :D Sent from my SM-G930T using Tapatalk Read all the threads of disappointed XJ owners who went down that rabbit hole. Over and over and over. I decided to start this thread because it can help someone. I got a lot of inspiration from other's threads like from racer32, John D, PhotoJared, Frank Z, Jeff 98XJ WI, etc.. I would like to thank all the XJ LS swapers. Excuse my english. My XJ is a 2001 sport. I put a M62 supercharger in it to get more power, but I was not very satisfied. Then I put a comp cam 232-4, piggyback ecu, wideband, headers but the results was poor for the effort. So I decided to go the LS route because I knew the engine from Corvette and I very like the V8 sound and torque production. Now I am at the middle of the swap. (I hope). This swap began in Feb 2017 when I got the package from ebay: Very current thread from 'elsewhere'.................I have read this statement dozens of times. I learn from the mistakes of others. Spending thousands of dollars chasing the illusive HP/torque from a 4.0 No thanks.
MeanLemons Posted June 24, 2017 Posted June 24, 2017 Agreed. If the jeep didn't come with a 4.0, I wouldn't be putting one in.
Green Mesa XJ Posted June 24, 2017 Posted June 24, 2017 For the carbureted XJ/MJ plunking a carbureted chevy ought to be straight forward once the oil pan and engine mounts are sorted. I believe there is a adapter to fit the ax-15 to chevy small block. I like the idea of a 318 too. Sent from my iPhone using Tapatalk Pro
Jtrux Posted June 25, 2017 Posted June 25, 2017 I'm leaning towards a non-Jeep engine swap also. My MJ has a 2.5L and it would be about the same money for me to swap an LS vs a 4.0 unless someone gave me a 4.0 XJ for free to swap it all over. Sent from my LGLS992 using Tapatalk
