offthepavement Posted May 9, 2017 Posted May 9, 2017 i would like to exchange the fuel injectors ☺ but have no clue what would be a great fit for this comanche????mid priced proven injectors for a late 89 comanche 4.0L 4×4 part time I6 Sent from my LG-V410 using Tapatalk
Eagle Posted May 9, 2017 Posted May 9, 2017 http://comancheclub.com/topic/52487-before-i-order-injectors-are-they-definitely-bad/
offthepavement Posted May 9, 2017 Author Posted May 9, 2017 sweet yeah does that have anything to do with the kinda like starting off in first it wants to like how do i describe it uuhh it does a jolt forward maneuver in first and second.well it does it when i let off the gas and then apply again its just like yeah jolty...i guess i could clean the throttle also .I'm sure it hasnt been done in years(10)at least.is there any wires that i shouldnt unplug and spray down with electric cleanser stuff spray ??? yall -thanks Sent from my LG-V410 using Tapatalk
DirtyComanche Posted May 9, 2017 Posted May 9, 2017 sweet yeah does that have anything to do with the kinda like starting off in first it wants to like how do i describe it uuhh it does a jolt forward maneuver in first and second.well it does it when i let off the gas and then apply again its just like yeah jolty... That might be normal. It doesn't drive like a modern vehicle with fancy dampening crap. You have to ease in and out of the throttle if you're at lower RPM. But cleaning the throttle body, IAC, and all the sensor grounds isn't going to make it worse...
IronManche87 Posted May 9, 2017 Posted May 9, 2017 sweet yeah does that have anything to do with the kinda like starting off in first it wants to like how do i describe it uuhh it does a jolt forward maneuver in first and second.well it does it when i let off the gas and then apply again its just like yeah jolty... That might be normal. It doesn't drive like a modern vehicle with fancy dampening crap. You have to ease in and out of the throttle if you're at lower RPM. But cleaning the throttle body, IAC, and all the sensor grounds isn't going to make it worse... Amen!
