SUA Recessed U-bolt Plate
SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config :
Where do you get these...?!? Please :)
Also, where'd ya mount your shocks? Any random place...?
Thanks!
The original pic was of a Toyota Tacoma with a 2-1.2" wide SUA conversion. I'm still in the dimension info gathering mode to make sure they will fit my D44 w. MT springs. Here's a couple of links where you can get these plates:
https://www.yotamast...-u-bolt-plates/
http://www.ruffstuff...alog/R2198.html
EDIT:  I have found out since that the the RuffStuff Specialties u-bolt hole dimensions are:
"Width wise (across the spring) it's 4 7/8" center hole to center hole. Lengthwise it's 3 3/4" center hole to center hole but then are elongated to fit multiple axle tube diameter's. These plates are drilled to accept 5/8" u-bolts."
I plan on modifying my existing u-bolt plates with a welded on angle iron leaf pack cradle on the top surface of my existing u-bolt plates since there is enough real estate to do it. Thanks to 1989 comanche mj
for giving me the angle iron idea.
