HOrnbrod Posted March 19, 2017 Posted March 19, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config :
1989 comanche mj Posted March 20, 2017 Posted March 20, 2017 That u bolt plate is great! Nice looking spring stack too. Where can I get the plate, for an 8.8 ford rear? The sliders are super nice also, probably cut down on rear steer but look pricey.
Rohls Posted March 21, 2017 Posted March 21, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config : Where do you get these...?!? Please :) Also, where'd ya mount your shocks? Any random place...? Thanks!
Jeep Driver Posted March 21, 2017 Posted March 21, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config : Yes, I too want those plates, where? Please.
HOrnbrod Posted March 21, 2017 Author Posted March 21, 2017 The original pic was of a Toyota Tacoma with a 2-1.2" wide SUA conversion. I'm still in the dimension info gathering mode to make sure they will fit my D44 w. MT springs. Here's a couple of links where you can get these plates: https://www.yotamast...-u-bolt-plates/ http://www.ruffstuff...alog/R2198.html EDIT: I have found out since that the the RuffStuff Specialties u-bolt hole dimensions are: "Width wise (across the spring) it's 4 7/8" center hole to center hole. Lengthwise it's 3 3/4" center hole to center hole but then are elongated to fit multiple axle tube diameter's. These plates are drilled to accept 5/8" u-bolts." I plan on modifying my existing u-bolt plates with a welded on angle iron leaf pack cradle on the top surface of my existing u-bolt plates since there is enough real estate to do it. Thanks to 1989 comanche mj for giving me the angle iron idea.
HOrnbrod Posted March 21, 2017 Author Posted March 21, 2017 Ruffstuff makes a kit Err, I think I mentioned that above..........
Crash Posted March 21, 2017 Posted March 21, 2017 I was using TT on my phone, and thought their other kit was different.
HOrnbrod Posted March 21, 2017 Author Posted March 21, 2017 ^^ $150 and they don't wrap the leaf springs. No thanks.........
Jeep Driver Posted March 31, 2017 Posted March 31, 2017 I just got my Ruffstuff cradles today, they come unwelded and will need to be welded.
Jeep Driver Posted April 3, 2017 Posted April 3, 2017 They will not work for me, conflicts with shock mounts. I'll sell them for cost. Welded, primed, painted. Ad in classified.
WyoCherokee Posted April 4, 2017 Posted April 4, 2017 i found a set as well...but spendy. $80 seems more my speed. http://ok4wd.com/shop-by-vendor/rock-equipment/rock-equipment-u-bolt-flip-plates-rear-dana-35-44-60-amc20-2-2-5-leaves
