HOrnbrod Posted March 19, 2017 Share Posted March 19, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config : Link to comment Share on other sites More sharing options...
1989 comanche mj Posted March 20, 2017 Share Posted March 20, 2017 That u bolt plate is great! Nice looking spring stack too. Where can I get the plate, for an 8.8 ford rear? The sliders are super nice also, probably cut down on rear steer but look pricey. Link to comment Share on other sites More sharing options...
Rohls Posted March 21, 2017 Share Posted March 21, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config : Where do you get these...?!? Please :) Also, where'd ya mount your shocks? Any random place...? Thanks! Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 21, 2017 Share Posted March 21, 2017 SUA spring plate u-bolt length eliminator. Provides a little more clearance for SUA config : Yes, I too want those plates, where? Please. Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 21, 2017 Author Share Posted March 21, 2017 The original pic was of a Toyota Tacoma with a 2-1.2" wide SUA conversion. I'm still in the dimension info gathering mode to make sure they will fit my D44 w. MT springs. Here's a couple of links where you can get these plates: https://www.yotamast...-u-bolt-plates/ http://www.ruffstuff...alog/R2198.html EDIT: I have found out since that the the RuffStuff Specialties u-bolt hole dimensions are: "Width wise (across the spring) it's 4 7/8" center hole to center hole. Lengthwise it's 3 3/4" center hole to center hole but then are elongated to fit multiple axle tube diameter's. These plates are drilled to accept 5/8" u-bolts." I plan on modifying my existing u-bolt plates with a welded on angle iron leaf pack cradle on the top surface of my existing u-bolt plates since there is enough real estate to do it. Thanks to 1989 comanche mj for giving me the angle iron idea. Link to comment Share on other sites More sharing options...
Crash Posted March 21, 2017 Share Posted March 21, 2017 Ruffstuff makes a kit Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 21, 2017 Author Share Posted March 21, 2017 Ruffstuff makes a kit Err, I think I mentioned that above.......... Link to comment Share on other sites More sharing options...
Crash Posted March 21, 2017 Share Posted March 21, 2017 I was using TT on my phone, and thought their other kit was different. Link to comment Share on other sites More sharing options...
ScottJeep Posted March 21, 2017 Share Posted March 21, 2017 http://www.currieenterprises.com/CE-9031C Link to comment Share on other sites More sharing options...
HOrnbrod Posted March 21, 2017 Author Share Posted March 21, 2017 ^^ $150 and they don't wrap the leaf springs. No thanks......... Link to comment Share on other sites More sharing options...
Jeep Driver Posted March 31, 2017 Share Posted March 31, 2017 I just got my Ruffstuff cradles today, they come unwelded and will need to be welded. Link to comment Share on other sites More sharing options...
Jeep Driver Posted April 3, 2017 Share Posted April 3, 2017 They will not work for me, conflicts with shock mounts. I'll sell them for cost. Welded, primed, painted. Ad in classified. Link to comment Share on other sites More sharing options...
WyoCherokee Posted April 4, 2017 Share Posted April 4, 2017 i found a set as well...but spendy. $80 seems more my speed. http://ok4wd.com/shop-by-vendor/rock-equipment/rock-equipment-u-bolt-flip-plates-rear-dana-35-44-60-amc20-2-2-5-leaves Link to comment Share on other sites More sharing options...
