1986 Jeep Comanche LWB Command-Trac, 2.5 litre 4x4. Body ia a little rough but sound. Runs good. Has a leak in the clutch slave cylinder so you have to pump the clutch up a few times before you take off if you haven't driven it in a while.
2.5 litre Iron Duke 4 cylinder
All New brake system, master cylinder, braided lines, rotors, pads, EVERYTHING!
New Ignition Module
Recent tune up with new plugs and wires too
New Starter
Spectre water cooled air filter
4" lift kit
Zone Shocks
  • 2 years later...
  • 1 year later...
JM62
*ZZ
-ZZ
ADL SKID PLATE GROUP
AJY Popular Equipment Package
BAC 75 AMP ALTERNATOR
BCQ Battery - 750 Amp Maintenance Free
CGX Head Restraints-Outboard Seating, RR
DDQ Transmission - 5-Speed Manual
EPD ENGINE - 2.5L I4 TBI GAS
GAC ALL WINDOWS - TINTED GLASS
GEC Window - Left Side, Front, Sliding
GSC MIRROR - RIGHT BLACK
HAA AIR CONDITIONING - FRONT
HCC HEATER W/UPR LEVEL VENTIL - TYPE II
JAY Instrument Cluster w/Tach
JGB Clock - Digital
JHA WINDSHIELD WIPERS - DELUXE
JJA CIGAR LIGHTER - FRT COMP
K60 BODY SIDE MLDGS - VINYL
LAP FUEL ECONOMY SHIFT INDICATOR LIGHT
LMA HALOGEN HEADLAMPS
LNJ DUAL ROAD LAMPS
MBJ Bumper - Front, Black
MCA FRONT BUMPER GUARDS
MCB REAR BUMPER GUARDS
MD8 Delete Front License Plate Bracket
MFD BRIGHT GRILLE - TYPE I
NAA ESA W/CATALYST (EXC CALIF SYSTEM)
NFA TANK - 20 GAL FUEL
NMB ENGINE COOLING - STANDARD DUTY
RAC RADIO - AM/MTR
SBA POWER STEERING
SCE STRG WHL - EURO/SPORT TYPE
SUA TILT STEERING COLUMN
