omega_rugal Posted March 19, 2017 Posted March 19, 2017 is the 42RE better, worse or similar to the AW4? the reason is there`s a grand cherokee (ZJ) i can get for cheap, it also has a 4.0 HO and runs pretty well, the interior is in very bad shape but the rest is good, if i were to get it i plan to have it as a donor for the MJ, engine tranny and whatever fits any site i can find more data on this tranny?
Minuit Posted March 19, 2017 Posted March 19, 2017 Compared to the AW4, the 42RE is made out of tissue paper. They tend to die very often. Don't bother.
omega_rugal Posted March 19, 2017 Author Posted March 19, 2017 really? oh well at least i got a good 4.0 to play with... and some good tires...
1989 comanche mj Posted March 20, 2017 Posted March 20, 2017 Yep aw4 is way better than all the chrysler made trannys. Chrysler still doesn't make good trannys.
omega_rugal Posted March 20, 2017 Author Posted March 20, 2017 anything else i can use from the ZJ besides the engine? or are these just turds with wheels?
Green Mesa XJ Posted March 20, 2017 Posted March 20, 2017 If it has rear disc brakes those are a good swap. Sent from my iPhone using Tapatalk Pro
Crash Posted March 20, 2017 Posted March 20, 2017 You can use the front axle shafts as spares if they are in decent shape. Drive shafts, at least the front may work or you co ld sell it to someone who needs a certain length shaft
omega_rugal Posted March 20, 2017 Author Posted March 20, 2017 If it has rear disc brakes those are a good swap. has rear disk brakes but is a Dana 35, not swapping my 44 for it just for the brakes, unless the 44 breaks somehow it`s a 2wd so no front axle... again only if my current one breaks...
Green Mesa XJ Posted March 20, 2017 Posted March 20, 2017 I think they'll fit with a little trimming. How'd you get so lucky to find a Dana 44? Sent from my iPhone using Tapatalk Pro
omega_rugal Posted March 20, 2017 Author Posted March 20, 2017 luck, came with it... some PO must have swappedit thought...
HOrnbrod Posted March 20, 2017 Posted March 20, 2017 Yep aw4 is way better than all the chrysler made trannys. Chrysler still doesn't make good trannys. The 727 Torqueflite was one of the best AT's ever made. It couldn't be killed, and is still used today.
