Wiper motor wiring help!
Hey guys I'm doing a 97+ swap on my Comanche it's a 90 my trouble is I forgot to snag the windshield wiper motor from my donor. I have the 90 motor and all the wiring is from a 98. I was wondering if anyone had the pinout from a 90 XJ/Mj with the round rubber plug and the 98 oval plastic plug so I can mate the two together. Or if someone has pictures of the motor with the wires going into so i can have wipers and pass state inspection. Thanks guysaa95ea98162466e071b3ffe0a8856184.jpga655661a773561b29ead5fbebb312391.jpg
The wiring for the 90 can be found in the 88 electrical FSM  http://comancheclub.com/topic/12083-electrical-manual/
From searching on Morris Jeep in the knowledge section, there is a FSM for 96-01 XJ. In the wiring diagrams, under the wiper motor:
DG/YL - Park
BR/VL - High
BR/WH - Low
DB - Pwr
BLK - Ground
To connect the 90 to the 98:
PWR: 90 LG/BK = 98 DB
Park: 90 TN/BK = 98 DG/YL
Low: 90 WH/BK = 98 BR/WH
High: 90 DB/WH = 98 BR/VT
Ground: 90 BK = 98 BK
Honestly your best bet is to find a 97+ wiper motor. It I'll be easier and will be less wiring mess. You can sell your 96- wiper motor for about what you can buy a 97+ wiper motor for.
  • 1 year later...
