charlierebel Posted January 6, 2017 Share Posted January 6, 2017 please help guy's!!! I have 1986 comanche 2.5L. need new valve cover and I was told a valve cover off a Chevy S10 2.5l will work as Chevy was supposed to have made these engines. Is this correct & can I use a valve cover off an older S10 2.5L???? Link to comment Share on other sites More sharing options...
omega_rugal Posted January 6, 2017 Share Posted January 6, 2017 i don`t think so... Link to comment Share on other sites More sharing options...
Hippie66 Posted January 6, 2017 Share Posted January 6, 2017 Nope. OReilly Auto Parts has new for $64.99 though. Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 7, 2017 Share Posted January 7, 2017 The 2.8L was the GM engine. The aftermarket has 2.5L valve covers... And there's millions in junkyards. Link to comment Share on other sites More sharing options...
gogmorgo Posted January 7, 2017 Share Posted January 7, 2017 A lot of people think the MJ/XJ 2.5L is a GM engine, possibly because of the 2.8, possibly also because AMC did very briefly use Pontiac's Iron Duke 2.5L. But it's not the case. The Jeep 2.5L is an AMC engine. It was also used in later years with the Dakota I believe, along with the XJ. Later ones may have better valve covers and gaskets, but I can't speak to compatibility. Link to comment Share on other sites More sharing options...
Rockfrog Posted January 14, 2017 Share Posted January 14, 2017 The 2.5L used in the MJ/XJ/YJ/TJ was an AMC design derived from the 4.2L in line six. Ironically the 2.5L was produced by more or less removing the 2 middle cylinders from the 4.2L. The later 4.0L was created by adding them back into the 2.5L. The 2.5L Iron Duke used in S10's was only used in the CJ 5/7's and that was a GM motor. Sent from my SM-G930W8 using Tapatalk Link to comment Share on other sites More sharing options...
