Has anyone gone soa with metric ton springs? I've searched around and can't find any info on it? Bought my first comanche a couple of months ago and I am starting to get a list together on what I need for a lift. I have found the Alexia lift posts so I have a pretty good idea of what I need. Just wondering about the metric ton springs in the rear.
No reason why you couldn't.  :thumbsup:  going SOA lifts it 5-6" over whatever height it is now.  I added leafs to firm up my standard packs when I went spring-over.
nope, you're good. :thumbsup:   weight carrying ability doesn't affect the gain from a spring-over conversion.  Now, you might be on the high end of what you'll need to hike up the front, but not any more than a set of 4x4 leafs in good shape.  From the factory the Metric ton leafs didn't sit any taller than regular packs.  They just resisted sag better.  :yes:
I understand why the ride would be the same from factory, but with the two extra overload springs on a metric ton pack wouldnt that add an extra 1-2 inches once you flip the springs?
I have thought about going soa, but my metric ton springs are near brand new and I'm worried I would end up with enough lift to put me somewhere in the stratosphere.
A SUA to SOA swap will net the exact height of the leafs + mount + half the axle tube. This is on all trucks no matter what. Spring capacity or condition does not affect number this at all.
I understand that, but the metric ton springs have more leafs in the pack than the standard pack meaning they are thicker and more lift will result, yes?
If you stuck a 1" block under the springs while still SUA nothing would change, but if you flip the springs on top, THEN add the 1" block you would gain an additional 1" of lift. I havent measured them, but I'm pretty sure the MT springs are thicker than the standard pack. By how much? I don't know. But whatever the difference is, that is how much more lift would be achieved using MT springs vs standard capacity.
Also, why only half the axle tube?
it's a tiny amount.  all our trucks have 1 overload so if he had the double overload variety, it'd mean an extra half inch maybe (thickness of that one leaf).  If he has the other variety, it'd be a quarter inch.  :thumbsup:
I think your missing my point still. the exact amount of lift is the exact height of the leafs+mount+halftube.    so yes there will be slightly more lift in a metric ton spring then a standard spring. but its a precise amount. its nonvariable.  so you could figure that out right now in the driveway.
Alright so I get that but like ftpiercecracker1 asked why only half the axle tube?
My MT springs are 2.25in
The stock spring mount is .5in
And half of my danna 44 tube is 1.375in
Add that all together and you get 4.125in lift
But if I add the full tube at 2.75in I get 5.5in lift which is what it should come out to
SOA lift is measured above axle/hub centerline.   similar to how going from a 30" tire to 32" tire is only 1" of lift. even though its a 2" increase.
Ah. You are correct. I forgot to double the equation to compensate for the mirroring effect. (1/2tube+mount)2+Springpack. Albeit it is still a known variable lift. And can be near perfectly equated regardless of weight capacity changes.
Pete: LOL
Ok cool, so it is just as i suspected. Going SOA with MT springs will net slightly more lift than standard capacity, not because of the difference in capacity but simply because the leaf packs are thicker.
So the final equation would be
leaf pack thickness + perch height + full axle tube diameter.
I went out and braved the harsh FL winter (73° @ 10pm) to measure for my self.
A little over 5.5" maybe 5 5/8"?
Also forgot to mention I have a chry 8.25, larger tubes than a D35 right?
Just for reference, here is a pic with standard leafs.
