In need of a harness for the tail lights. Just the pig tails for the bulb sockets. the wires are broke right at the connector, and no way to crimp them. If i could just get a whole harness with 4 to 5" of wire to crimp or just the reverse bulb sockets with 4 to 5 inches of wire to solder/crimp that would be great!
I have one that I had cut about a foot away from the main plug so if you still need one rather than cut a good one let me know I can get this one boxed and shipped.
That would be perfect. is it just the reverse socket, or all three?
It's the whole harness. I cut it right at the grommet where it comes out of the cab. I accidentally stepped on the plug and smashed it and I needed the grommet for my custom harness. I'll take pictures when I get home in about 2 hours.
Edit: if you just need a small part of it I can cut it off and send that as well.
So I forgot it was two parts. I cut the front section that has the fuel pump on it. The rear section is complete.
got a pic of it.?
Here is a picture of the rear most part of the harness 6da485cf3d953d1f44b499eae7315b39.jpg
And here's one of the front part of the harness. Notice where I cut it to remove it from the truck. I ended up not needing the grommet so that is still there.
Sent from my HTC6525LVW using Tapatalk
Hey! Along the same lines, I'm in need of a passenger side tail light cover. Anyone got one? Or maybe one of those 2 junkyard MJs have one?
  jeep-comanche-pickup-19886-1987-1988-pas
I have a complete tail light wire harness that is unaltered and complete. I don't know what its worth, but I got one. If you want it, let me know and we can work something out......mostly with shipping
