WyoCherokee Posted December 19, 2016 Posted December 19, 2016 In need of a harness for the tail lights. Just the pig tails for the bulb sockets. the wires are broke right at the connector, and no way to crimp them. If i could just get a whole harness with 4 to 5" of wire to crimp or just the reverse bulb sockets with 4 to 5 inches of wire to solder/crimp that would be great!
Minuit Posted December 19, 2016 Posted December 19, 2016 If you're still needing one by tomorrow I'm going to a junkyard that has 2 MJs. I could get the harness.
Dzimm Posted December 19, 2016 Posted December 19, 2016 I have one that I had cut about a foot away from the main plug so if you still need one rather than cut a good one let me know I can get this one boxed and shipped.
500 MJ Posted December 19, 2016 Posted December 19, 2016 I have some pig tails too if other options don't work.
WyoCherokee Posted December 19, 2016 Author Posted December 19, 2016 I have one that I had cut about a foot away from the main plug so if you still need one rather than cut a good one let me know I can get this one boxed and shipped. That would be perfect. is it just the reverse socket, or all three?
Dzimm Posted December 19, 2016 Posted December 19, 2016 It's the whole harness. I cut it right at the grommet where it comes out of the cab. I accidentally stepped on the plug and smashed it and I needed the grommet for my custom harness. I'll take pictures when I get home in about 2 hours. Edit: if you just need a small part of it I can cut it off and send that as well.
Dzimm Posted December 19, 2016 Posted December 19, 2016 So I forgot it was two parts. I cut the front section that has the fuel pump on it. The rear section is complete.
WyoCherokee Posted December 22, 2016 Author Posted December 22, 2016 So I forgot it was two parts. I cut the front section that has the fuel pump on it. The rear section is complete. got a pic of it.?
Dzimm Posted December 22, 2016 Posted December 22, 2016 Here is a picture of the rear most part of the harness And here's one of the front part of the harness. Notice where I cut it to remove it from the truck. I ended up not needing the grommet so that is still there. Sent from my HTC6525LVW using Tapatalk
JaysJeep Posted February 10, 2017 Posted February 10, 2017 Hey! Along the same lines, I'm in need of a passenger side tail light cover. Anyone got one? Or maybe one of those 2 junkyard MJs have one?
Warrior Spit Posted February 23, 2017 Posted February 23, 2017 I have a complete tail light wire harness that is unaltered and complete. I don't know what its worth, but I got one. If you want it, let me know and we can work something out......mostly with shipping
