Power Brakes Question ?
My power brake fluid is leaking
and i was wondering if anyone knew an easy way to fix it
it is leaking where the Master cylinder connects to the Power Brake Booster
on the bottom part of the master cylinder
do i have to replace the master cylinder or
is there something that i can just put on in between there
to get the leak to stop?
i will also post a pic for you guys to see
it would be great to get my brakes working like new
i have put new pads on the front and new shoes in the back
also i bleed the lines and put new fluid in it
thats when i noticed the leak
the Master cylinder looks like it just needs a light cleaning and it will look ok
but the Power Brake Booster defiantly needs more then just a light cleaning
its seen better days :(
any advice will help guys thanks for reading
ok so i just unbolt the old M.C.
and bolt in a new M.C.
then add new fluid and thats it
can anyone tell me the proper way to replace it
and what to do to get the brakes working correctly after I'm done replacing the part?
also will a master cylinder repair kit work or do i just have to buy a new M.C.
http://www.rockauto.com/en/moreinfo.php?pk=907419&cc=1181393&jsn=453
Buy a new master cylinder.  You will need to bench bleed it, don't skip this (google or you tube bench bleeding a m/c).  Then swap it out, top off, then you will need to bleed the brakes.  If you haven't done that yet, you may find your bleeder screws are rusted shut.  Start treating them now with a rust penetrant like pb blaster or the like.  Treat them daily several days before doing the work.  If one snaps off you will have to replace that caliper or wheel cylinder.
Now would be the time to swap to a dual diaphragm booster from a 96 XJ for better power brakes.  Your power brake booster could be damaged from that m/c leak (or maybe not).  If you do the swap, the booster must use the matching 96 master cylinder.  However this requires some brake line work which may be over your head based on your questions.
ok i will take it apart tomorrow
and see if the brake booster can be reused
or if it must be replaced
i will also try to post a pic of what it looks like taken apart
hopefully a auto parts store will have it in stock
https://www.napaonline.com/napa/en/search/?text=Brake%20master%20cylinder&isApplication=true&isInterchange=true&referer=herofitmentForm-newveh#
I agree with schardein OP, the 95-96 XJ dual diaphragm brake booster upgrade is leaps and bounds much better than the original set up even in "brand new condition". There's tons of info on the upgrade from many forums since it is very popular, but it will require a bit more work and maybe tools.
yes i see that the dual diaphragm brake booster is better because it pushes out more pressure
but I'm just going to keep it simple and put a new regular one for now
i also got a new flare wrench set
it the SAE one i thought that since the vehicle is made in the USA it would not have any metric size nuts on it
For the brake lines, the SAE set is the one you need. But elsewhere ... the XJ and MJ came out during the period when AMC was merged with Renault, which is a French company. Also, that was right at the time when the U.S. automobile industry was on a push toward metrication. You're going to find that most of the nuts and bolkts on the engine are SAE, but most of the nuts and bolts on the body and chassis are metric. For regular wrenches and sockets, you're going to need both metric and SAE.
After researching I would agree. I have one sitting waiting to be installed on my MJ.
