Tach not working
with out any pics of how it looks hooked up in the vehicle i can't really determine what could have went wrong
when you say your Tach isnt working
do you mean that all of the gauges work
but the RPM gauge does not work?
also tell us what year your MJ is
the guy in your link did it in a 87 XJ
so he might have already had a RPM gauge even in his old dash
witch made the swap to the new one super easy for him
Its a 1990 2.5l ax4 rwd
The cluster on the top is my old one with the "idiot lights" and I swaped in the more upgraded one
I switched my oil pressure sender and engine temp sender to sensors.
After driving it around all other guages work except the tach.
ok that help me out so i believe
since you have a in line 4 motor and your vehicle is 2 wheel drive
you have no sensor from your tranny telling the dash what your rpm is
i think the only way to get it to work
is to take the tranny to a tranny shop and have them put in a sensor
so that you can hook it up to your rpm dash gauge
now i may be wrong but I'm pretty sure that since the original dash did not have an rpm gauge
then why would they install a tranny that has a rpm sensor in it ???
on the other hand you might be lucky
they might have the sensor in the tranny
and they just never ran the wire for it up to the dash
i would look at the tranny and see if there is any evidence of an electrical connection and go from there
This is incorrect. The tach should work out of the box. The signal comes from the ignition system and every MJ is equipped for it, whether it originally had the tach or not. I've converted two trucks now and the tach has worked correctly both times. Check that the two plugs are snapped in all the way (on my '89, sometimes they won't go in completely and the gauges won't work) and check the ground under the dashboard. You mentioned everything else works fine, so neither of those are probably the issue but they're still worth checking. Other than that, I've never personally had a tach go bad but if everything else checks out I'd start suspecting the tachometer gauge itself may be bad. You might also want to look for any nicks or tears in the cluster's printed circuit board. Let me know what you determine.
I have quite a few parts for these Renix clusters (no complete ones, sadly) so if you need another tach or a printed circuit board I could probably help you out.
If I remember correctly, there are two contacts where the tach head attaches to the printed circuit. Under the hood, there are two small, yellow "thingies" (highly technical term there) with flip caps on them. Inside, there are contacts for running some basic diagnostics. The smaller of the two has six terminals (receptacles). That's the one with the feed for testing the tach. You can check it by taking the cluster out of the dashboard and running jumpers from the test terminals to the tach head.
I'm not set up to scan the diagram of the diagnostic connector. As drawn, it shows two columns and three rows. The right side of the block has two notches cut out of it. Oriented that way, top right is #1, #2 below that, #3 bottom right ... then #4 top left, #5 below that, and #6 bottom left. #1 is the positive tach feed. #3 is the ECU ground -- you can use that for the tach ground, or just ground it to the engine block.
My assumption would be in using a tach from a 6 cylinder engine in a four cylinder engine doesnt work. Since it is based on the ignition system, wouldn't that change based on how many cylinders are firing? Sorry if this is incorrect information.
It will 'work' even if it's the wrong one.  It just reads incorrectly.
^^^ What he said.
what exactly do you guys mean when you say it runs off of the ignition system
The tachometer is electronic, not mechanical. It receives electrical pulses and "counts" them, converting that into an RPM reading. The electrical pulses for the tachometer come from the ignition. What it's doing is counting how many times the coil sends a spark to the spark plugs.
congrats bro at least you figured it out and got it to work
does it work correctly or is the reading off at all ?
Good news that he got it working.
If the "new" cluster came from a 6-cylinder, the tach probably doesn't read correcttly. The good news is that that style cluster is the newer style ("newer" as it relates to the Renix years, with the mechanical speedometer), and those have a potentiometer on the back of the tachometer that can be used to adjust it to read correctly for a 4-cylinder. If it came from a 4-cylinder, no adjustment should be required.
Thank you guys for all the input, i ended up just taking it out and plugging it back in and everything works! I must have not had it all the way plugged in  :doh:
Always the simple stuff! :thumbsup: Sometimes those plugs don't want to go all the way in for whatever reason.
