I am a recent owner of a 1987, 2wd, 4.0, MJ. The truck has 82,000 Miles on her, and I have noticed when I run around 65-75MPH the truck gets a slight jerking feeling. Almost feeling like a misfire on the engine, but not. It seems to mainly do it at high speeds, low rpm while going up a hill, or putting alil more strain on the engine. Now I have noticed if I give it some gas, the truck doesn't really jolt, only if I gradually hit the gas and ease into it at high speeds. Here is a list of things I replaced when I bought the truck....
- NEW PLUGS
- NEW WIRES
- DISTRIBUTER CAP
- ROTOR
- AIR FILTER
- CLEANED THROTTLE BODY
- CHANGED OIL AND FILTER
Go to my website and do Tips 1 through 5 to begin with.
Awesome write up, I will go through and check these items this week/weekend. Thanks for the quick response
You bet. Enjoy.
Check your spark plug wires. If they are the originals, the insulation may have broken down and they may be losing spark energy to any metal they pass near. When this happens, it feels like a misfire -- mostly because it is a misfire.
He replaced them. Does act like a secondary ignition issue though.
Sorry -- I missed that.
Yeah, but the symptoms mimic that.....
Hmmmm, sounds like that "bucking" thing. Ahh, I do remember the first time I felt it, rolling down I-10 at 75 mph with my son (maybe 2005-ish?)....and we looked at one another with the "what the hell was that" look.
Hard to believe, 1987 with only 82k? I hit that around 1998 and that was with the truck sitting about three years while I was in Germany.
After you work through Cruisers tips....please check back in because coil and EGR come to my mind, but not with only 82,000 miles. Meaning, don't buy parts first. Do the simple and tedious things since they may cure your problem (and they need to be done since they will solve/fix/help so many little things). 29 years is still 29 years, things corrode, gunk hardens, stuff leaks.
Lol yes sir. 82,000 miles, no rust, solid all around. Just purchased it about a month ago. So getting the hang of this MJ thing.
Oh boy, hope you find the issue. My 92 started that way and after months of troubleshooting (problem was intermittent and sometimes left the truck undriveable) it turned out to be a bad electrical connection.
Sent from my SM-G930T using Tapatalk
I have an 87 with a 4.0.  I had the same issue years ago.  My issue turned out to be a cracked sense tube from the throttle body to the MAP sensor.  My temporary fix was to heat shrink the cracked tube.  I purchased a new tube from the dealer and the problem was solved.  I can only hope it would be this simple for you.
Those tubes are no longer available. Here's an alternative fix.
http://cruiser54.com/?p=280
Is there anything that needs to be hooked up here?
I only ask because I found this line just hanging in the engine bay near it, with a plug in it.
Which connects here
Looks like someone unplugged the EGR valve and plugged it's hose.
This help?
That print out is great. Thank you. Why would you think they would do that at curiosity? Shouldn't that be connected?
This help?
Always remember this:
Genius has it's limits, but stupidity knows no bounds.....
This help?
So is it possible this jolting is due to the hose not being hooked up to the EGR valve
I did do the C101 Elimination. Soldered wire connections than put heat shrink tube over, taped up, and will get wire loom tomorrow.
But I am Just slowly going over your steps. Sorry for all the questions. Just trying to make sure I don't miss something. As always I appreciate all the help
