jdritchey98 Posted October 4, 2016 Posted October 4, 2016 A friend of mine with a 90 MJ pioneer is replacing his front axle seals and discovered this broken plastic piece. Any help with what it's called or even a part number would be nice. Its located behind the 4we actuator on the driver side of the axle housing. Here's the part: And here's where it's located: Sent from my LG-H634 using Tapatalk
fiatslug87 Posted October 5, 2016 Posted October 5, 2016 Maybe this will help. If you can't make out the part numbers on the right let me know which ones you're interested in.
yxmj Posted October 5, 2016 Posted October 5, 2016 Best guess is it is this http://picclick.ca/Dana-30-Axle-Shaft-Inner-Dust-Slinger-Jeep-262612520337.html
fiatslug87 Posted October 5, 2016 Posted October 5, 2016 Is it a delaminated part of #26 in the above diagram? PN 83504813. http://www.morris4x4center.com/shift-collar-with-disconnect-axle-83504813.html or http://autoplicity.com/2791370-axle-shaft-collar?utm_source=ShoppingCom&utm_medium=CSE&utm_campaign=ShoppingComNOFITMENT or https://www.amazon.com/gp/offer-listing/B003AONO74/ref=sr_1_5_olp?ie=UTF8&qid=1475686533&sr=8-5&keywords=83504813&condition=new
yxmj Posted October 5, 2016 Posted October 5, 2016 He says it is plastic.... The collars I. Have seen are metal??
fiatslug87 Posted October 5, 2016 Posted October 5, 2016 The description Morris gives says it is metal and rubber. I've never worked on the axles so I don't know. :dunno:
jdritchey98 Posted October 6, 2016 Author Posted October 6, 2016 So I found out what the part is. For all of you guys it is this part right here: http://www.quadratec.com/products/52406_13.htm Sent from my LG-H634 using Tapatalk
fiatslug87 Posted October 6, 2016 Posted October 6, 2016 :banana: :banana: :banana: :banana: :banana:
jpdriver1 Posted October 7, 2016 Posted October 7, 2016 please excuse the interruption of this thread if rebuilding the dana 30 to be non-disconnect using solid axles, is this bearing needed? or is it replaced with the seal? thanks We now return you to the thread already in progress
