jdritchey98
Everything posted by jdritchey98
  1. Alright good to know, mine does have a Dana 44 in It though is why I figured it was. Sent from my ASUS_Z01KD using Tapatalk
  2. Pretty sure I got the metric tonne package but mine looks like its only got 4 leave. Sent from my ASUS_Z01KD using Tapatalk
  3. I definitely don't plan on destroying the 87. It basically needs a new bed on it as well as floor pans. I might consider converting the 89 to a manual. I know I prefer a manual over an automatic. I know a lot more about manuals than autos. Sent from my ASUS_Z01KD using Tapatalk
  4. I did most of what cruiser has mentioned above when I first got it. I can somewhat drive it with the TCM unhooked but it still does it. I also have an 87 MJ same everything but it's a 5 spd ax15. Was planning on fixing up the 87 but there's quite a bit of rust and I got rear ended in a parking a lot a year ago and insurance wouldn't do anything. A friend of mines neighbor has had this 89 for a while and he got put in a nursing home and I was told they was selling truck or scraping it so I bought it. Only had it a couple of months still messing with a lot of it don't get much time to work on it. Gonna try adjusting the tv cable tomorrow morning and see if it helps any. Will update after I try that. A mechanic friend of mine told me to check the screen/filter to see if it was dirty but haven't had time to do that yet. Picture is the 89. 87 is red one in background. Sent from my ASUS_Z01KD using Tapatalk
  5. I have an 89 MJ 4.0 4x4 Auto Aw4. The problem I'm having is when I get in to go somewhere I back the truck down my driveway shift into drive or 1st and start going down the road. I have to go up a hill either direction I go. When I start going up the hill I get to about 10mph and then the truck acts like its in neutral. I can give it some more gas and it still doesn't go. It will actually roll backwards down the hill while in drive. If I shift it into third it changes gear just fine but still acts like its in neutral. After some more revving and shifting back and forth it finally jerks like something coming unstuck and then drives like it should the rest of my drive. My driveway is an incline as well but the truck also does this after being parked on flat ground while I'm at work. My TPS tests good. All 3 transmission solenoids ohm good. The NSS is also good. It does this whether the TCM is hooked up or not. Fluid level is also correct. Only thing I havent done is pull the pan and check the screen or try adjusting the tv cable. Sent from my ASUS_Z01KD using Tapatalk
  6. The REM shows whether its in open/closed loop as well as whether the egr solenoid is on or off which would tell you if the valve is open or closed. Sent from my LG-H634 using Tapatalk
  7. That got taken off and cleaned really well I didn't like it either lol Sent from my LG-H634 using Tapatalk
  8. 1. It idles normally around 700-900 until it starts to warm up then the idle slowly increases by the 100's the longer the engine runs and sometimes when I First start it up it starts right away around 2k and never goes down. I can shut it off and restart and it will sometimes jump up and then go back to where its suppose to idle or it will idle even higher than 2k. One day I started it and it went straight to 3k. 3. The grommet and tube on back of valve cover are brand new as well as all the vacuum lines on and around the intake. 2. The egr is working as its suppose to I assume. It cycles open and closed at idle (700-900rpm) but only at idle. just wasn't sure how often its suppose to cycle when the egr opens the engine runs slightly smoother. I live in arkansas no inspections here. I do know my coolant temp sender on side of block is bad and my exhaust is pretty much non existent after the cat. Haven't been able to change the coolant temp sensor cause its been really cold and have no idea how to get to it without taking the intake off. Sent from my LG-H634 using Tapatalk
  9. First off, I have an 87 MJ 4.0 5 spd and yes I have cleaned the throttle body, iac, and adjusted the tps. Also have done most of cruisers tips on grounds and other stuff. Also have a REM Clock panel version. 1. First, every time I push my clutch in at a stoplight or to change gears I noticed It makes my engine idle 1000rpm higher. 2. Also is the egr valve suppose to be opening and closing while cruising down the highway and such because mine is not according to my REM as well as my vacuum pressure goes down the more I press the gas pedal. Not sure if it's suppose to go up or down. 3. Throttle body was pretty dirty. Was soaked with oil as well as air filter and box had oil in bottom of it. Ideas where it might be coming from. Sent from my LG-H634 using Tapatalk
  10. This is the second time this has happened to me. Here in Arkansas it's been raining a lot and last time this happened it was a real humid day just after a heavy rain so I'm thinking it has to do with the moisture. The issue is when I turn one of my turn signals on it shuts my radio off and the turn signal doesn't do anything. The first time it happened it fixed itself after a 15 minutes drive to town, this time it hasnt. Also this time when I turn my blower on to any setting but a.c.(no a.c. in my truck) it also turns the radio off and doesn't work. Any ideas as to a cause I am stumped on this one, my dad says it's probably a short somewhere but I wouldn't no the first place to look for one cause any other day it works perfectly fine. Sent from my LG-H634 using Tapatalk
  11. So I was sitting in my mj the other day while in town and went to put something in my glove box. I went to open it and it wouldn't so I thought maybe I locked it, so I stuck my key in and found out it was unlocked. So now my issue is my glove box with my registration and a couple other things are stuck in it. Any ideas how I can get it to open?? Of you ouch the button on the passenger side in it stays in unless I stuck something thin inside and push it back out. Sent from my LG-H634 using Tapatalk
  12. So I found out what the part is. For all of you guys it is this part right here: http://www.quadratec.com/products/52406_13.htm Sent from my LG-H634 using Tapatalk
  13. A friend of mine with a 90 MJ pioneer is replacing his front axle seals and discovered this broken plastic piece. Any help with what it's called or even a part number would be nice. Its located behind the 4we actuator on the driver side of the axle housing. Here's the part: And here's where it's located: Sent from my LG-H634 using Tapatalk
  14. Ok any reccomendations on brand and how often to change it. I'm hoping to change it Monday as long as my new fill plug is here by then. Sent from my LG-H634 using Tapatalk I assume you got the fluid changed already, but I'll still entertain your questions. I use Mobil 1 in the transmission, the same as I use in the motor, and change it every other year because I do not daily drive the truck anymore. I think a yearly change would suffice in a daily driven truck.I'm just changing it cause I don't know when it was last changed. I'm gonna put valvoline synchromesh in it. Right now I'm fighting my rounded filler plug trying to get it out. Whenever I get a few miles on the valvoline I'll do a small short little post on how well it does. Sent from my LG-H634 using Tapatalk
  15. Ok any reccomendations on brand and how often to change it. I'm hoping to change it Monday as long as my new fill plug is here by then. Sent from my LG-H634 using Tapatalk
  16. That's not good. Where's your thermostat? MIA?What do you mean thatd not good. Right now in arkansas it's not super hop like I described it was during the summer but my MJ has ran at the same temp since I got it. Here's proof of where it runs and this pick was on a really hot day with lots of sitting still in traffic and I have no a.c.: Sent from my LG-H634 using Tapatalk
  17. I live over here in Arkansas where it's 95 and 85% humidity and my mj just has the mechanical fan and runs at about 160 170 degrees. Sent from my LG-H634 using Tapatalk
  18. I was looking is valvoline syncromesh any good. I can't seem to find penzoil sycromesh without ordering it and paying a lot for shipping. Sent from my LG-H634 using Tapatalk
  19. How well do they fit because I might get one cause my dash is cracked right on top of the instrument cluster. Sent from my LG-H634 using Tapatalk
  20. So because my transmission has been swapped when I get parts like the clutch or slave cylinder of flexplate do i need to get the parts as an 89 instead of an 87. Also is it ok to put some anti-seeze on the tiller plug when I put a new one in. Sent from my LG-H634 using Tapatalk
  21. When I broke my passenger side tailight I was able to get a set of red and red tailights and a sport truck roll bar for $100 from a junkyard. Sent from my LG-H634 using Tapatalk
  22. I was just wanting to know for sure that was the drain plug before I pulled it out. The bell housing comes off the front of the transmission and it doesn't look like the case splits lengthwise and the slave is internal. Sent from my LG-H634 using Tapatalk
  23. So I finally got time to get back under the truck and curious if this is the drain plug on my trans. This picture is on the driver side. Sent from my LG-H634 using Tapatalk
  24. It will be tuesday(tomorrow) before I will be able to look at it again but I will check it out. I will post back on what trans it is when I find the fill plug. I found what looks to be the drain plug on the bottom passenger side of the trans when I took the pictures. Sent from my LG-H634 using Tapatalk
  25. It had been sitting for 6 months in the previous owners driveway cause he had got a newer vehicle. Before that I don't know what has been done to it. I've oy had the truck for a year now and still finding stuff I haven't noticed. Sent from my LG-H634 using Tapatalk
