Changing the tail light bulbs
Went to replace the tail light bulbs and in all 4 stop lamps there was this yellow stuff that kind of looks like dried up play-doh... is that something that is supposed to be there or is it something that the PO did that I should clean up? 33eac30d6c1cc3c07b9497e9207c2102.jpg62c813051e5218d8b90adfd8177892db.jpg
Sent from my SM-G930P using Tapatalk
Dielectric grease is what you use sparingly on electrical connector boots to seal out moisture. An example is spark plug boots. As long as you didn't gob a spoonful of grease inside the socket between the bulb and socket contacts you should be fine.
  • 4 months later...
