Marine1Texas Posted September 17, 2016 Share Posted September 17, 2016 2 days ago i noticed in to 1st and reverse my clutch was not going in all the way.when my clutch pedal go's in I have a small twist. Seems like a small crack has happen on the lever that makes the peddle twist and not push all the way.with my hand I can make it go in straight and the clutch is completely disengage. So I have checked local junk yards and no assembly's that will fit my 87 mj. Is there a part number for the whole unit or we one know where to get one? If not I will try to weld it. Sent from my ASUS_Z00AD using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted September 17, 2016 Share Posted September 17, 2016 Is the big bolt that holds it in tight? The nut on it could be loose letting it move around. Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 17, 2016 Author Share Posted September 17, 2016 yes it is all tight here a picture Link to comment Share on other sites More sharing options...
Eagle Posted September 17, 2016 Share Posted September 17, 2016 I don't think a part number will help you, since the part hasn't been available through AMC/Daimler/Chrysler/Jeep/Fiat for decades, and that's not the sort of part an aftermarket maker would produce. Either weld it or start checking junkyards. Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 17, 2016 Author Share Posted September 17, 2016 Yea I will probably weld it. I was just hoping that there is a part that could order. Yea will weld it and then keep looking. Sent from my ASUS_Z00AD using Tapatalk Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 17, 2016 Share Posted September 17, 2016 The clutch pedal p/n is 53004363. It was used on 86-90 XJ/MJ models. Good luck finding a new one. Link to comment Share on other sites More sharing options...
Rockfrog Posted September 18, 2016 Share Posted September 18, 2016 Most I have seen were cracked, and then rewelded, even mine has been welded together as it cracked at some point in the same spot. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 18, 2016 Author Share Posted September 18, 2016 Thanks Rockfrog! I just never herd of it before, I will just weld it! Link to comment Share on other sites More sharing options...
Marine1Texas Posted September 19, 2016 Author Share Posted September 19, 2016 Welded it up today. I notice the metal they use it very weak. I think I am good shape for a while. Link to comment Share on other sites More sharing options...
