Help ID Mystery Nut/End Plug That Fell Out Of Front Of Motor
I pulled off my front bumper to install new factory brush guard and tow hooks with appropriate brackets. When I went to test install (shoved in the new bumper/guard/brackets) to see if was a good fit, this thing fell out.  I'm pretty sure it was a part that the PO let fall into all the rubber mats, or front skid plate etc. underneath the front of the truck and never retrieved, but I would still like to know what it is.  5/16 or 16mm.
Thanks,
Rick
That's what it looks like to me, but I'm manual tranny.  Although, radiators can be universal (manual/auto) so maybe you're right!  I'll look underneath my radiator tomorrow and see if it's the same as any "bungs" there.  I'm sure it's just a "lost part", but nice to know which one... :)
Pretty certain that will be the plug for the trans cooler part of the rad, as 'almost' all rads come with the trans cooler in them and just have them plugged if you aren't using it. It's inverted flare, not much else uses inverted flare (nothing I can think of on an XJ/MJ, except brakes, which that is not).
