jdritchey98 Posted July 25, 2016 Share Posted July 25, 2016 I need to know where i can find one of these or what I can interchange with it. If someone had a part number for it that would be helpful as well. I currently work at Oreilly and I can't find the elbow in our system. I know it's for the ccv/pcv system. Sent from my LG-H634 using Tapatalk Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 25, 2016 Share Posted July 25, 2016 Dorman 46003 Link to comment Share on other sites More sharing options...
schardein Posted July 25, 2016 Share Posted July 25, 2016 The Renix experts will probably chime in, but I believe that is the main crankcase vent hose, and is only available as an assembly that includes other hoses. There are two halves to the assembly, and that side would be considered the engine side. The junction of the two halves is near the front of the intake manifold. Link to comment Share on other sites More sharing options...
schardein Posted July 25, 2016 Share Posted July 25, 2016 Back when I had a Renix Wagoneer, replacing that entire assembly was money well spent, rather than trying to repair it a piece at a time. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 26, 2016 Share Posted July 26, 2016 Dorman 46003 And 46004 is the other side of the harness, since it's probably buggered too. Link to comment Share on other sites More sharing options...
jdritchey98 Posted July 26, 2016 Author Share Posted July 26, 2016 That part number will help me a lot thanks greatly I'm actually needing the entire setup of that hose. I'll post another picture showing why. Keep in mind that this hose has been this way since I got that truck. I have replaced the grommet on the back of the valve cover and broke the vaccum line for it in the process and still have to replace it. If you notice anything that doesn't look right feel free to ask or tell about it. Sent from my LG-H634 using Tapatalk Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 26, 2016 Share Posted July 26, 2016 That P/N is half of the entire vacuum harness setup. The P/N I posted (one digit higher) is the other half. They're about $20 each online. I don't have the P/N for the line from the rear of the valve cover that you broke, but I believe it is available from Dorman also. Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted July 26, 2016 Share Posted July 26, 2016 Dorman 46005 is the rear hose and it also comes with the grommet . Link to comment Share on other sites More sharing options...
