I just picked up a 2wd 88 eliminator and id like to do a 4x4 conversion. What all will i need to do to accomplish this task? I believe all i will need will be a front axle trans and matching t-case all linage involved a bell housing and a front driveshaft. Now this is my plan: I'd like to do a Dana 30 with 4:10 gear ratio, a bell housing from a late 93+ Cherokee with the external slave, an AX15 trans with matching NP231 t-case 23 spline, a new center console to account for the 4x4 shifter lever, and a custom front driveshaft. Now am i able to keep my original rear axle or will i have to swap that as well, And if i can keep it how can i change it to make it work with the 4:10 gear ratio i'm seeking? Let me know if i'm missing or forgetting anything. I'm also looking to give it a 3"-4.5" lift. With that lift what size tire would ​you recommend? I'm thinking of running 35's. ​​ :driving:
