colt45
Everything posted by colt45
  1. I just picked up a 2wd 88 eliminator and id like to do a 4x4 conversion. What all will i need to do to accomplish this task? I believe all i will need will be a front axle trans and matching t-case all linage involved a bell housing and a front driveshaft. Now this is my plan: I'd like to do a Dana 30 with 4:10 gear ratio, a bell housing from a late 93+ Cherokee with the external slave, an AX15 trans with matching NP231 t-case 23 spline, a new center console to account for the 4x4 shifter lever, and a custom front driveshaft. Now am i able to keep my original rear axle or will i have to swap that as well, And if i can keep it how can i change it to make it work with the 4:10 gear ratio i'm seeking? Let me know if i'm missing or forgetting anything. I'm also looking to give it a 3"-4.5" lift. With that lift what size tire would ​you recommend? I'm thinking of running 35's. ​​ :driving:
  2. i just picked up a 2wd 88 eliminator and id like to do a 4x4 conversion. what all will i need to do to accomplish this task. i believe all i will need will be a front axle trans and matching t-case all linage involved a bell housing and a front driveshaft. now this is my plan: id like to do a dana 30 with 4:10 gear ratio, a bell housing from a late 93+ cherokee with the external slave, ax15 trans with matching np231 t-case 23 spline, and a new center console to account for the 4x4 shifter lever
    1. colt45
      colt45
      probably have to do a custom front driveshaft
