I have an ax15 out of a 94 cherokee in my 89 4.0 Comanche I am replacing the trans mount but can't find one that fits the trans mount that's in it now from the previous owner (I think it's from a ba10 or something like that) is all cut up so it would fit. Does someone make a mount for an ax15 in a Comanche? Is it something custom I would have to make? What can I do. Thank you. I would post a pic of the old mount but I don't know how.
You need this mount, the trans crossmembers were different between the BA-10/5 and AX-15, the AX-15 one has an indentation but people say both will work. Might have to move it back I think. From Rockauto (search for 94 XJ or 90 MJ, you'll get the same items):
that looks exactly like the one I just bought but doesn't fit. the ax15 has 4 bolts in it and the crossmember has 4. The mount that I took off also has the exhaust bracket.
So you're looking for the bracket that bolts to the trans and then the above mount attaches to it and the crossmember.
yes! That's exactly what I'm looking for jt I can't find one anywhere. Do you know of any were that sells them?
You need part number 52003927, the one above has a different exhaust hanger and looks different. There's one on eBay for 99.99 with good pictures, can't seem to post the link but it's item number 331839345144. Parts.com claims to have it.
defiantly going to try and buy that later today thank you. I couldn't find that anywhere.
