1J7FT26L9KL583830
Minuit
ENGINE & PERFORMANCE:
Stock engine and transmission. Volvo fuel injectors added by previous owner.
DRIVETRAIN:
2 wheel drive. AX-15 manual transmission, open differential Dana 35 rear axle.
COOLING:
Open cooling system conversion with standard single-core radiator and factory 2.5L overflow tank. Heater control valve deleted.
ELECTRICAL & IGNITION:
Stock with significant repairs. Stock replacement ignition components. Fusebox replaced due to clutch master cylinder damage.
STEERING:
Stock; most parts replaced with standard replacements.
SUSPENSION:
INTERIOR:
Mixed bag; Cordovan dash, door panels, kick panels, B-pillars, and lower sill trim. All other parts Charcoal. Final interior color undecided. Factory rubber floor with blown original speakers. AMC RX-135 radio.
AIR CONDITIONING:
Stay tuned!
BRAKES:
Front and rear disc brakes. Stock with new rear drum components.
LIGHTING:
Relay-controlled headlamps with Hella H4 composite housings. Factory retrofit fog lights, wired in stock configuration.
WHEELS/TIRES:
15x7 Jeep "Gambler" wheels with 235/75/R15 Cooper Discoverer A/T3 tires.
Build Threads:
2012-2016, owned by relyt120
2016 - present, owned by Minuit
  • HOrnbrod changed the title to 1J83830 7FT26L9KL583830
*B1 TRIM STYLE B1 - CLOTH && VNL BENCH SEAT
-SA Charcoal
161 Zone 61-Atlanta
1AA U.S. Dealer Retail
5AL Low Series Tracking
APA Monotone Paint
BAY 105 Amp Alternator
BCY BATTERY, 58-475 CC
BGA Power Front Disc/Rear Drum Brakes
BJA STD DUTY FRT DISC BRAKES
BKP 10x2.5 Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAA Instrument Panel
JAZ DO NOT USE - See JP, KA classes
JBF Instrument Panel Black Bezel
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
JKB MOPAR Hood Lock
K3Z STRIPE/BADGE/MOLDING/COLOR
KDB STRIPE/BADGE/MOLDING
LAF Seat Belt Alert-Driver Seat only
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MLDG - TYPE I
NAA Federal Emissions
NBA LIGHT DUTY CYCLE
NBK EVAP Control System
NDA Catalytic Converter
NF2 18.5 Gallon Fuel Tank
PE8 DARK VIVID RED PRIMARY PAINT - HE8
QE8 DARK VIVID RED SECONDARY PAINT - HE8
RAA All Radio Equipped Vehicles
RAC AM MTR Radio
RCA 19 SPKRS SRT High Perf Audio
SBA Power Rack and Pinion Steering
SCB Perforated Steering Whl w/Red Stitch
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TAD HIGHWAY TREAD
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
XFA -35F Protection Anti-Freeze
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Body model TL61
Build Date 4/9/89
  • 1 year later...
