CEThomas Posted July 3, 2007 Posted July 3, 2007 Went off and forgot to lookup the type and amount ot fluid need for the 231 t-case and AW-4. Thanks,
Wildman Posted July 3, 2007 Posted July 3, 2007 Both the AW4 and the 231 should take Dexron/Mercon ATF AW4 = Appox 4 quarts, run to hot, thru all gears and re-check, Don't over fill. 231 = Appox 2 quarts, filled to top of filler hole. I doubled checked both of the spects for your "mid" '90's equipment ;)
Pete M Posted July 3, 2007 Posted July 3, 2007 231 = Appox 2 quarts, filled to top of filler hole. That might be a bit of a challenge. :D An easier method is to fill to the bottom of the filler hole. :cheers:
CEThomas Posted July 3, 2007 Author Posted July 3, 2007 It was not to bad, just put the MJ on end and filled till it was to the top of the neck. Problem was getting the MJ back down on the ground :rotfl2:
deziped Posted July 3, 2007 Posted July 3, 2007 What, not up to the challenge? If your quick with the plug you can fill to top & maybe catch it :eek: half-way to the bottom edge of the hole. Serves no useful purpose, but, its fun to try if you don't mind oil possibly down to your elbow.
DirtyComanche Posted July 3, 2007 Posted July 3, 2007 I fill mine above the top fill hole. But I fill it on the bench out of the truck. And you can use whatever ATF you want in a 231. They don't care. Although, I do personally like the Dex/merc stuff.
Wildman Posted July 4, 2007 Posted July 4, 2007 So......I typed that up side down :D I ment "Fill to top filler hole" So if some one want to stand the MJ on it noise, more power to them :bowdown:
DirtyComanche Posted July 4, 2007 Posted July 4, 2007 Actually, it's a common trick for guys who own SWB jeeps with horrid steep rear pinion angles to park facing down a steep hill to fill the rear diff.
rockhardzj Posted July 4, 2007 Posted July 4, 2007 Actually, it's a common trick for guys who own SWB jeeps with horrid steep rear pinion angles to park facing down a steep hill to fill the rear diff.What's a d35 call for?I was told 3.5 quarts, but only have been able to get around 2.5 in. It's kind of needed info, for my daily driver ZJ...
Wildman Posted July 6, 2007 Posted July 6, 2007 What's a d35 call for?I was told 3.5 quarts, but only have been able to get around 2.5 in. It's kind of needed info, for my daily driver ZJ... Yea, I had to double checked this - And the D35 calls for 3.5 PINTS (Not Quarts) of SAE 80W/90. So, if your only getting 2.5 qts in, then your over filled, cause 3.5 pts equals a little less than 2 qts. This is based on <'94. >'94 calls for 3.7 pts.
