Suspension / 4wd conversion question
OK, I've searched the site for hours on end, and want to ask a question specific to my situation.
1991 MJ shortbed, 4.0, auto, 2wd.
I plan to convert to 4wd.  Already have the rear D44 and front high pinion non-cad D30.  Rear will get 3.73s to match the front.  Already have NP242.  Only missing piece is transmission, rear driveshaft and some odds/ends.
I want to run a 30x9.50/15 tire (or something close in metric).
I don't plan to do any serious off roading, I have CJs for that.  But if I do, I don't want them to rub.
I think I need some lift to run the 30" tires.  I don't want it to be any taller than necessary.  Level stance preferred, or slight rake is ok.
What are some recommendations for front/rear springs?
I am considering the General Spring 1700lb capacity rear springs.  I am thinking those will result in a higher ride than my 1991 2wd leafs.
If that's a good choice, what is a good match for the front spring?
255/70R15's look great on my brother's XJ with nothing but a budget boost in the front, work very well in sandy conditions, and are pretty much the same overall diameter as 235/75's. He's running General AT's on Canyons with no rubbing.
The GS 1700lb MT springs initially netted me close to 3" of lift, eventually settling down to a bit over 2". To level it all out I used a set of OME 930 coils up front. It all settled out over time to a nice stance with a slight rake. I run 31" tires, plenty of room, and the ride and handling is a big improvement over stock especially with an XJ 1-1/8" sway bar up front and an ADDCO WJ bar in the rear.
You will also need an adjustable track bar and a few shims behind the LCAs to correct caster.
You don't need any lift. I have 30x9.50/15s on my '87 shortbed, at stock height. I had 31x10.50s on the '88 when I removed the lift and I left them on for about a year. The 31s are now under my original '88 Cherokee -- again, with no lift.
