mikekaz1 Posted April 19, 2016 Share Posted April 19, 2016 yeah its roughly 216*/218* that its SUPPOSE to come on and then off at 195*/200* or something like that, like so, mine would follow that 15*/20* start stop process. but it wouldn't start till ~250* and off at ~235* for some reason Link to comment Share on other sites More sharing options...
acerocknroll Posted April 19, 2016 Author Share Posted April 19, 2016 I fully installed the e-fan today just to see what happens, didn't hear it come on while driving to work but I'll keep an ear out. Temps do seem to slowly creep back down under heavy acceleration (which unfortunately I don't do much of driving around town) so maybe the new fan clutch is doing it's job? Did get that new cap, no change. At this point I'm not really sure what else to try? Link to comment Share on other sites More sharing options...
shelbyluvv Posted April 19, 2016 Share Posted April 19, 2016 Rising temp under heavy throttle usually points to a collapsing lower radiator hose. Does it have the spring in it? Link to comment Share on other sites More sharing options...
acerocknroll Posted April 19, 2016 Author Share Posted April 19, 2016 Sorry, I meant that temps actually do go DOWN (slightly) under heavy throttle. And both hoses are new, lower has spring. Link to comment Share on other sites More sharing options...
Tex06 Posted April 19, 2016 Share Posted April 19, 2016 Looks like internal resistance in the connections could be a factor. Have you tried cleaning out your connectors? http://comancheclub.com/topic/48804-electric-cooling-fan-issue/?p=496754 On voltage readings, corrosion can cause all kinds of havoc. Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 19, 2016 Share Posted April 19, 2016 that's where I believe my issue is, aging connections, although they all look decent, and my truck originally came with no E-fan, I dunno, weird sheet. Link to comment Share on other sites More sharing options...
acerocknroll Posted April 19, 2016 Author Share Posted April 19, 2016 Yeah the wires for the ECU connector look pretty nasty so I'm sure that's not helping. I'll probably just rig up a direct switch soon. Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 19, 2016 Share Posted April 19, 2016 Yeah the wires for the ECU connector look pretty nasty so I'm sure that's not helping. I'll probably just rig up a direct switch soon. if you follow that link 3/4 posts up, that was my actual issue and I believe I listed what I did to bypass/ solve it also Link to comment Share on other sites More sharing options...
mikekaz1 Posted April 19, 2016 Share Posted April 19, 2016 I tagged the end of that thread too, but then here the continuance of that(my) issue http://comancheclub.com/topic/48847-reverse-light-cooling-fan-electrical-issue/ Link to comment Share on other sites More sharing options...
acerocknroll Posted April 19, 2016 Author Share Posted April 19, 2016 Awesome, thank you! That is super helpful. I'm also gonna try switching the new fan clutch for a ZJ one, will report back if that helps. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 20, 2016 Share Posted April 20, 2016 http://cruiser54.com/?p=35 Link to comment Share on other sites More sharing options...
xjrev10 Posted April 27, 2016 Share Posted April 27, 2016 My setup... Parts store special radiator New hoses Old school green anti freeze Flow cooler water pump 180 degree t stat New fan clutch Renix with open cooling. Fan is the OE fan on a manual switch. I kick the fan on at 200ish. Never seen the temp over 205 with this setup...yet. Fan is rarely needed. With this truck, I don't care about efficient operation, I want it to work. It still makes enough heat to get comfortable in the cab below 20 degrees also. Link to comment Share on other sites More sharing options...
