RustyRodder Posted February 19, 2016 Posted February 19, 2016 So my comanche has the slider rear window, all intact luckily. problem is that I am missing the latch/handle bit thats normally on the sliding bit. Is there any sort of replacement or handle I could put on it so I can actually use it?
gogmorgo Posted February 19, 2016 Posted February 19, 2016 I'm curious about this as well. My slider's latch is busted too.
MiNi Beast Posted February 19, 2016 Posted February 19, 2016 you can steal bracket off another junkyard ride, i have sourced some from s10 chevys. can make a bracket or screw/glue a latch as well. i used a paint stick to "lock" the window if thats a concern.
HOrnbrod Posted February 20, 2016 Posted February 20, 2016 Any of these work? http://www.autozone.com/collision-body-parts-and-hardware/sliding-window-latch-kit http://www.gordonglassusa.com/group/663/CRL-Replacement-Latches.htm
