Could someone get me that speedo gear chart? I can't find t anywhere. I got my tax return so I got some money to spend so after months of no speedo I thought maybe I should get her going again.
Which transfer case did you use? The original from your truck or the one from the xj?
The one from the xj. But ever since I swapped it in I haven't gotten the gears to mesh up but I haven't really spent more then 2 minutes trying to figure it out haha.
As mentioned above you would need a 35tooth long shaft hear to keep running the mechanical speedo gear...
Just a twist speed position will get it back to spec for your set up...
It did take a bit of maneuvering to get it right when I swapped my mechanical speedo gear to a 96 np231
