dkmcgowan Posted February 2, 2016 Posted February 2, 2016 I'm looking to fix up the engine bay and I need a map sensor tube with both rubber ends. I'm fine if you don't have the tube or it's destroyed, I can make a new one with brake line or some new tubing. I don't have either of the rubber ends, the one that pushes into the throttle body and the one for the map sensor that is smaller diameter for the rubber tube and larger on the other end to stick onto the map sensor. Thanks!
500 MJ Posted February 2, 2016 Posted February 2, 2016 I can probably help out here, I will let you know tonight. Can you verify your year and engine? All of the ones I have will be for an '87-'90 4.0L. Thanks,
dkmcgowan Posted February 2, 2016 Author Posted February 2, 2016 1989 4.0 renix, so those years should be good.. Thanks!
HOrnbrod Posted February 2, 2016 Posted February 2, 2016 This? http://www.dormanproducts.com/itemdetail.aspx?ProductID=17825&SEName=46004
dkmcgowan Posted February 2, 2016 Author Posted February 2, 2016 This? http://www.dormanproducts.com/itemdetail.aspx?ProductID=17825&SEName=46004 Nope, not that one, already have that one... That is one of the two pieces for all the other connections. Neither of the two harness include the map sensor plug and tube. It has a special two hole rubber grommet thing that shoves into the throttle body and another rubber connector on the other end that has a small hole on one end and a larger one on the other. No one makes it anymore, 53004589 is the part number, no replacements out there. I can make a new tube for it np, I just want the rubber ends, but will take the tube if someone has one already in good shape.
HOrnbrod Posted February 2, 2016 Posted February 2, 2016 I have plenty of those small plastic tubing ends I've picked up here and there you can have if 500 MJ doesn't have them. My MAP is on the throttle body so I don't need them. Just let me know which ones you need.
Dom U Posted February 9, 2016 Posted February 9, 2016 I have plenty of those small plastic tubing ends I've picked up here and there you can have if 500 MJ doesn't have them. My MAP is on the throttle body so I don't need them. Just let me know which ones you need. If you have the end that goes into the throttle body in good condition I'll buy, as I live in Cali and all the yard parts are sun baked and cracked as hell.PM price and PayPal (:
HOrnbrod Posted February 9, 2016 Posted February 9, 2016 I have plenty of those small plastic tubing ends I've picked up here and there you can have if 500 MJ doesn't have them. My MAP is on the throttle body so I don't need them. Just let me know which ones you need. If you have the end that goes into the throttle body in good condition I'll buy, as I live in Cali and all the yard parts are sun baked and cracked as hell.PM price and PayPal (: I don't have the one for the Renix throttle body - sorry..........
