gnx1117 Posted January 17, 2016 Share Posted January 17, 2016 I want to use fromt and rear diffs auto tranny transfer case out of the xj and put it in my mj will this be easy or hard??? Link to comment Share on other sites More sharing options...
87MJTIM Posted January 18, 2016 Share Posted January 18, 2016 You will need to have the rear drive shaft from the XJ lengthened, or the DS from you MJ shortened. Most everything else should be a direct swap. There are lots of write ups on converting 2wd to 4wd. Just search on here for it. Link to comment Share on other sites More sharing options...
gnx1117 Posted January 18, 2016 Author Share Posted January 18, 2016 Thanks. The Mj was converted to 4x4 by PO from what i can tell it is 92 cherokee transfer case and front diff. Also has 4.5 rusty lift. The only reason for the change to have matching running gear Link to comment Share on other sites More sharing options...
87MJTIM Posted January 18, 2016 Share Posted January 18, 2016 Matching gears is good thing! Link to comment Share on other sites More sharing options...
gogmorgo Posted January 18, 2016 Share Posted January 18, 2016 Getting the AW4 to play nice with your Renix may be tricky. http://www.naxja.org/forum/showthread.php?t=1053970 Link to comment Share on other sites More sharing options...
cruiser54 Posted January 18, 2016 Share Posted January 18, 2016 On 1/18/2016 at 6:02 AM, gogmorgo said: Getting the AW4 to play nice with your Renix may be tricky. http://www.naxja.org/forum/showthread.php?t=1053970 Something to do with speed sensor IIRC. Link to comment Share on other sites More sharing options...
